With the HP Chromebook the best of Google is at hand on a colorfully sleek and stylish notebook. Access your favorite websites instantly on a beautiful 11-inch diagonal HD display.
Stay online on the go
Take the HP Chromebook from your desk to the great outdoors while browsing the web, streaming videos, or using the latest Chrome apps, thanks to 802.11n Wi-Fi. -
Make a splash with color
HP Chromebook with strikingly rich color showing off your unique personality. The sleek design, finished in soft-touch paint, means you'll stand out from any crowd you find yourself in.
- HP Chromebook 11 G5 Education Edition - 11.6" - Intel Celeron N3060 - 4 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Celeron N3060 / 1.6 GHz (2.48 GHz) / 2 MB Cache
- Memory
- 4 GB LPDDR3 (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" WLED 1366 x 768 / HD
- Graphics
- Intel HD Graphics 400
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2
- Battery
- 3-cell
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Jack black, ash silver
- 20.5 cm x 28.6 cm x 1.84 cm
- 1.137 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.48 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 2 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- LPDDR3 SDRAM
- Speed
- 1600 MHz
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6" - TN
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
- Graphics Processor
- Memory Allocation Technology
- Shared Video Memory (UMA)
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Frame Rate
- 30 frames per second
- Camera Features
- Noise reduction, echo reduction, HP TrueVision HD
- Sound
- Stereo speakers, dual array microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Multi-touch touchpad, gesture function
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- IEEE 802.11, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Capacity
- 44 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- 2 x USB 3.1 Gen 1 (HP USB Boost) , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Google Drive (100 GB Cloud Storage) (free for 2 years)
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- CSA, UL, CCC, FCC
- Localization
- 1.137 kg
Sustainability Information
- ENERGY STAR Certified
- 5 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
