HP Chromebook 11 G4 Intel Celeron N2840 4GB 16GB 11.6" Chrome OS
Quicklinx: BSW6WS00 Mfr#: N1A81EA#ABU
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
With its powerful Intel Celeron processor and long-lasting battery, you’ll be perfectly equipped for both work and play with the HP Chromebook 11.
High quality and affordable, you can enjoy speedy loading, fast web browsing and HD graphics whether you’re using your Chromebook laptop at your office desk or on the move.
At just 1.28kg, this HP Chromebook is lightweight and easy to carry around, and measures 30cm x 20.57cm x 2.045cm so it’s compact enough to fit into your handbag or briefcase.
With up to 8.5 hours’ battery life, you can rest assured that you’ll be able to complete a full day’s work even if you’ve forgotten to pack your charger cable. Take advantage of speedy Wi-Fi technology and Bluetooth 4.0 for swift data transfer.
This model comes with 4GB installed memory and a display size of 11.6-inches.
Stay in control and minimise security risks with the embedded security chip and security lock slot – so only you have access to the data stored on your laptop.
  • Never slow down
    With long battery life, you can search, stream and chat through every class without having to recharge.
  • Stay connected
    Stay connected to the cloud through available 3G/4G LTE wireless connectivity. Work with confidence, knowing you can stay connected to content, classmates and applications.
  • Quiet, thin, and light
    Say goodbye to whirring fans. Your thin and light Chromebook 11 runs quietly, with no noisy hardware or unsightly vents thanks to an innovative design that eliminates the fan and easily fits in a backpack.
  • Easy to manage and deploy
    Manage 10s, 100s, even 1000s of Chromebooks with ease. The optional web-based Chrome Management Console1 makes it easy to deploy and control users, devices, and apps across a fleet of Chromebooks.
  • Google for Education
    Access a wide range of apps, books, and videos to build interactive curriculums and manage and deliver that content using Google for Education.
  • Chrome Web Store
    Immerse yourself in the exciting and ever expanding world of the Chrome Web Store and customize your Chromebook with the latest apps, tools, extensions and themes.
HP Chromebook 11 G4 - 11.6" - Intel Celeron - N2840 - 4 GB RAM - 16 GB eMMC - UK
Chromebook
Operating System
Chrome OS - English
Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache
4 GB DDR3L (provided memory is soldered)
Storage
16 GB eMMC
Display
11.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics
Input Device
ClickPad
Keyboard
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
3-cell
Security
Trusted Platform Module (TPM 1.2) Security Chip
Black (keyboard)
30 cm x 20.57 cm x 2.045 cm
1.28 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year , Limited warranty - battery - 1 year
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.58 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB (provided memory is soldered)
DDR3L SDRAM
Speed
1600 MHz
Storage
Main Storage
16 GB eMMC
Display
11.6" - TN
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 1280 x 720
Camera Features
HP TrueVision HD
Sound
Stereo speakers, microphone
Codec
Maxim Integrated MAX98090AETL+T
High Definition Audio
Input
Keyboard, ClickPad
Keyboard Layout
Multi-touch touchpad, touchpad with gesture support
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260
3-cell lithium polymer
36 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB 3.0 , USB 2.0 , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS Card)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 2 years)
Black (keyboard)
Security
Microphone with echo and noise-cancellation, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
UL, VCCI, BSMI, GOST, FCC, A-Tick, ICES
Localization
1.28 kg
Sustainability Information
ENERGY STAR Certified
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
