HP Chromebook 11" 11A-NB0000NA Celeron N3350 4GB 32GB Grey
Quicklinx: GDKSWS00 Mfr#: 187K7EA#ABU
Type: Chromebook
Display Size: 11.6in
Processor Model: N3350
Operating System: Google Chrome OS
Installed Memory: 4GB, 4GB
  • Celeron
  • IEEE 802.11n
More than 50 in stock
£165.84 ex VAT
£199.00 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
Built for everything you do, this small and light HP Chromebook with an Intel processor and vibrant 29.5 cm (11.6") diagonal HD display is perfectly portable with the power to last all day. Amazing, isn't it?
  • Chrome
    This easy-to-use operating system was designed to be fast in every possible way, while keeping you safe and more secure on the web.
  • Dual-core Intel Celeron processor
    The perfect combination of performance, power consumption, and value helps your device run smoothly and reliably with two processing cores to handle all your tasks.
  • High-definition display
    See your digital world in a whole new way. Enjoy movies and photos with the great image quality and high-definition detail of 1 million pixels.
  • Anti-glare panel
    Enjoy the sun and your favorite content with this anti-glare panel. Non-reflective and low gloss means you'll get less glare while you're outside.
  • SuperSpeed USB Type-C 5Gbps signaling rate and Power Delivery
    Power your device or plug in your external storage with this SuperSpeed Type-C USB port, featuring 5Gbps signaling data rate. And it's reversible, so you never have to worry about plugging in upside down.
  • 32 GB eMMC storage
    An embedded Multimedia Card provides reliable flash-based storage at a great value. And without the moving parts of a traditional hard drive, there's a lower chance of failure and damage.
HP Chromebook 11a-nb0000na - 11.6" - Celeron N3350 - 4 GB RAM - 32 GB eMMC - UK
Chromebook
Operating System
Chrome OS - English
Intel Celeron N3350 / 1.1 GHz (2.4 GHz) / 2 MB Cache
4 GB LPDDR4
Storage
32 GB eMMC
Display
11.6" 1366 x 768 / HD
Graphics
Intel HD Graphics 500
Input Device
Imagepad
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2
2-cell - up to 13 hours
Security
Google Security Chip H1
Ash grey, textured finish
30.6 cm x 20.8 cm x 1.8 cm
1.36 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
Limited warranty - parts and labour - 1 year - pick-up and return
Chromebook
Operating System
Google Chrome OS - English
Processor / Chipset
CPU
Max Turbo Speed
2.4 GHz
Number of Cores
Dual-Core
Cache
L2 - 2 MB
64-bit Computing
RAM
4 GB
LPDDR4 SDRAM
Speed
2400 MHz
Rated Speed
2400 MHz
Storage
Main Storage
32 GB SSD eMMC
Display
11.6"
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
45% NTSC colour gamut, HD anti-glare
Audio & Video
Graphics Processor
Camera
Yes - HD
Camera Features
HP TrueVision HD
Sound
Stereo speakers, microphone
Input
Keyboard, imagepad
Keyboard Layout
Multi-touch ImagePad
Communications
Wireless
Miracast, dual stream (2x2)
2-cell lithium polymer
47 Wh
Run Time
Up to 13 hours
AC Adapter
Output
45 Watt
Connections & Expansion
Headphone/microphone combo jack , 2 x USB-C 3.1 Gen 1 (supports DisplayPort 1.2 Alt Mode) (Power Delivery) , 2 x USB 3.1 Gen 1
Memory Card Reader
Yes (microSD)
Software
Software Included
Google Drive (100 GB Cloud Storage) (free for 1 year)
Security
Theft/Intrusion Protection
Security Slot Type
Kensington nano security slot
USB-C power adapter
Localization
1.36 kg
43.5 cm x 26 cm x 6.7 cm / 1.62 kg
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Type: Chromebook
Hard Drive Capacity: 32GB
Optical Storage: None
Graphics: Intel HD Graphics 500
Hard Drive Type: SSD
Touchscreen: No
Brand: HP
Stock Status: In stock
