HP Business Slim Keyboard with Smart reader
Quicklinx: D552WS00 Mfr#: Z9H48AA#ABU
Type: Keyboard
Colour: Black
40 in stock
£49.68 ex VAT
£59.61 inc VAT
Pair your PC with a sleek, restyled, reduced-size keyboard that packs a familiar layout, function keys, and number pad into a space-saving design. Updated key light indicators alert you when Caps lock, Num lock, and Scroll are on or off. Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out.
  • Bold redesign
  • Smart security
    Get a smart card reader that's conveniently located in line of sight at the top of the keyboard to help you remember to take your card out. Compatibility with Class A, B, and C smart cards helps prevent hacking and firmware changes in the keyboard.
  • Quiet and durable
    Keep your work environment quiet with lubricated keys, and breathe easy when minor spills happen with the built-in spill drain that makes the keyboard easy to clean.
  • USB connectivity
    Easily connect the keyboard to any USB port on your PC. The included 6 ft (1.8 m) USB cable gives you plenty of room to move the keyboard around your workspace.
  • World-class support
    Enjoy the reassurance of a one-year limited warranty.
HP Business Slim - keyboard - UK - black
Keyboard
USB
Wired
Localization and Layout
Security Devices
Smart card reader
44.06 cm x 14.45 cm x 1.98 cm
600 g
1-year warranty
EliteDesk 705 G5, 800 G5; EliteOne 800 G5; ProDesk 400 G6, 405 G4, 600 G5; ProOne 400 G5, 440 G5, 600 G5
Keyboard
USB
Input Device
Security Devices
Smart card reader
44.06 cm
14.45 cm
1.98 cm
600 g
Cable Length
1.8 m
FCC Class B certified, CSA, TUV, TUV GS, VCCI, BSMI, KCC, ICES, cULus, EAC, RCM, ISO 9241-410
Limited warranty - 1 year
10 °C
50 °C
10 - 90% (non-condensing)
HP EliteDesk 705 G5, 800 G5 , HP EliteOne 800 G5 , HP ProDesk 400 G6, 405 G4, 600 G5 , HP ProOne 400 G5, 440 G5, 600 G5
HP Business Slim Keyboard with Smart reader Bundle deal on HP Business Slim Keyboard with Smart reader
£148.85
Type: Keyboard
Colour: Black
Brand: HP
Price Range Ex VAT: 0 - 50
