Get fast data entry and quick USB connectivity with the HP USB Business Slim Keyboard, designed to complement the 2015 class of HP Business PCs.
Multi-OS compatibility
Interact seamlessly with a full-sized keyboard layout that's optimized for use with multiple operating systems. -
USB connectivity
Easily connect the keyboard to any USB port on your PC.
- HP Business Slim - keyboard - UK Input Device
- Keyboard
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Numeric Keypad
- 43.68 cm x 13.76 cm x 2.1 cm
- 600 g
- 1-year warranty
- Keyboard
- Interface
- USB
- UK
- Region
- United Kingdom
- Keyboard Technology
- Membrane
- Numeric keypad
- 43.68 cm
- 13.76 cm
- 2.1 cm
- 600 g
- Cable Length
- 1.8 m
- Limited warranty - 1 year
- 10 °C
- 50 °C
- 10 - 90% (non-condensing)
