Quickly and easily collaborate, chat online or listen to personal media with the crystal-clear sound and noise cancelling features of the sleek, lightweight HP Business Headset v2, designed to complement your professional workspace..
Easy comfort and connectivity
Connect the headset to your PC’s 3.5 mm audio/mic jack through the adapter and control volume from the headset cable. Adjust the headband to your preferred comfort setting and rotate the microphone boom left or right or move it out of the way.
Compatible with the newest collaboration technologies.
Work with what you know—the headset is designed for use with mainstream VoIP software and Skype for Business.
World-class support
Get the reassurance of a one-year limited warranty.
Connect the headset to your PC's 3.5 mm audio/mic jack through the adapter and control volume from the headset cable. Adjust the headband to your preferred comfort setting and rotate the microphone boom left or right or move it out of the way. -
Work with what you know-the headset is designed for use with mainstream VoIP software and Skype for Business. -
World-class support
- HP Business Headset v2 - headset
- Product Type
- Headset - wired
- Recommended Use
- Computer
- Localisation
- Hungarian / Hungary
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 100 - 12000 Hz - Sensitivity 100 dB
- Microphone
- Boom
- Controls
- Volume, microphone on/mute
- 1-year warranty
- Designed For
- HP 290 G1; Elite Slice for Meeting Rooms G2, Slice G2; EliteDesk 705 G3, 705 G5, 800 G2, 800 G5; EliteOne 1000 G1, 800 G2, 800 G5; ProDesk 400 G3, 400 G6, 405 G4, 490 G3, 600 G2, 600 G5; ProOne 400 G5, 440 G5, 600 G2, 600 G5
- Product Type
- Headset - wired
- 8.3 cm
- 18 cm
- 25 cm
- 459 g
- Recommended Use
- Computer
- Localisation
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 100 - 12000 Hz
- Total Harmonic Distortion (THD)
- 3%
- Sensitivity
- 100 dB
- Diaphragm
- 28 mm
Microphone
- Boom
- Sensitivity
- -44 dB
- 3%
Remote Control
- Controls
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
- Cable Details
- Headset cable - 2 m
- Limited warranty - 1 year
- Designed For
- HP 290 G1 , HP Elite Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Rooms , HP EliteDesk 705 G3, 705 G5, 800 G2, 800 G5 , HP EliteOne 1000 G1, 800 G2, 800 G5 , HP ProDesk 400 G3, 400 G6, 405 G4, 490 G3, 600 G2, 600 G5 , HP ProOne 400 G5, 440 G5, 600 G2, 600 G5
