HP Business Headset V2
Quicklinx: CKKLWS00 Mfr#: T4E61AA
Quickly and easily collaborate, chat online or listen to personal media with the crystal-clear sound and noise cancelling features of the sleek, lightweight HP Business Headset v2, designed to complement your professional workspace..
Easy comfort and connectivity
Connect the headset to your PC’s 3.5 mm audio/mic jack through the adapter and control volume from the headset cable. Adjust the headband to your preferred comfort setting and rotate the microphone boom left or right or move it out of the way.
Compatible with the newest collaboration technologies.
Work with what you know—the headset is designed for use with mainstream VoIP software and Skype for Business.
World-class support
Get the reassurance of a one-year limited warranty.
  • Easy comfort and connectivity
    Connect the headset to your PC's 3.5 mm audio/mic jack through the adapter and control volume from the headset cable. Adjust the headband to your preferred comfort setting and rotate the microphone boom left or right or move it out of the way.
  • Compatible with the newest collaboration technologies
    Work with what you know-the headset is designed for use with mainstream VoIP software and Skype for Business.
  • World-class support
HP Business Headset v2 - headset
Headset - wired
Recommended Use
Computer
Hungarian / Hungary
Headphones Form Factor
Full size
Wired
Sound Output Mode
Stereo
Audio Specifications
Frequency Response 100 - 12000 Hz - Sensitivity 100 dB
Microphone
Boom
Controls
Volume, microphone on/mute
1-year warranty
HP 290 G1; Elite Slice for Meeting Rooms G2, Slice G2; EliteDesk 705 G3, 705 G5, 800 G2, 800 G5; EliteOne 1000 G1, 800 G2, 800 G5; ProDesk 400 G3, 400 G6, 405 G4, 490 G3, 600 G2, 600 G5; ProOne 400 G5, 440 G5, 600 G2, 600 G5
Headset - wired
8.3 cm
18 cm
25 cm
459 g
Recommended Use
Computer
Hungarian / Hungary
Audio Output
Full size
Wired
Sound Output Mode
Stereo
Frequency Response
100 - 12000 Hz
Total Harmonic Distortion (THD)
3%
Sensitivity
100 dB
Diaphragm
28 mm
Microphone
Boom
Sensitivity
-44 dB
3%
Remote Control
Controls
Connector Type
Headphones (mini-phone stereo 3.5 mm) , Microphone (mini-phone 3.5mm)
Cable Details
Headset cable - 2 m
Limited warranty - 1 year
HP 290 G1 , HP Elite Slice for Meeting Rooms G2 for Skype Room Systems, Slice G2 Audio Ready with Microsoft Teams Rooms, Slice G2 with Intel Unite, Slice G2 with Microsoft Teams Rooms , HP EliteDesk 705 G3, 705 G5, 800 G2, 800 G5 , HP EliteOne 1000 G1, 800 G2, 800 G5 , HP ProDesk 400 G3, 400 G6, 405 G4, 490 G3, 600 G2, 600 G5 , HP ProOne 400 G5, 440 G5, 600 G2, 600 G5
