The HP BT04 Long Life Battery helps you be productive longer than the typical HP internal battery on the HP EliteBook Folio 9470m Notebook PC.
- HP BT04 - laptop battery - Li-Ion - 3520 mAh
- Laptop battery
- 335 g
- Battery
- Long life - Lithium Ion 4-cell - 3520 mAh
- 13.3 cm x 20.7 cm x 0.8 cm
- 1-year warranty
- Designed For
- EliteBook Folio 9470m, 9480m
- Laptop battery
- Long life
- Technology
- 4-cell Lithium Ion
- Voltage Provided
- 14.8 V
- Capacity
- 3520 mAh
- Recharge Time
- 2.5 hours
- Limited warranty - 1 year
- 0 °C
- 45 °C
- 13.3 cm
- 20.7 cm
- 0.8 cm
- 335 g
- Designed For
- HP EliteBook Folio 9470m, 9480m
