Product
HP BT04 4-cel 3520 mAh Li-Ion Laptop Battery
Quicklinx: 9B18WS00 Mfr#: 687945-001
The HP BT04 long life battery helps you be productive longer than the typical HP internal battery on the HP notebook PC.
HP BT04 - laptop battery - Li-Ion - 3520 mAh
Laptop battery
335 g
Long life - Lithium Ion 4-cell - 3520 mAh
Batteries Qty
1
13.3 cm x 20.7 cm x 0.8 cm
EliteBook Folio 9470m
Laptop battery
Long life
Quantity
1
4-cell Lithium Ion
Voltage Provided
14.8 V
3520 mAh
Recharge Time
2.5 hours
45 °C
13.3 cm
20.7 cm
0.8 cm
335 g
HP EliteBook Folio 9470m
