The HP BA06 Long Life Battery is a slice battery that slides onto the bottom of the HP EliteBook Folio 9470m Notebook PC to help you be productive longer than using the primary battery alone.
- HP BA06 - laptop battery - Li-Ion - 5400 mAh
- Laptop battery
- 780 g
- Battery
- Long life - Lithium Ion 6-cell - 5400 mAh
- 32 cm x 21.3 cm x 0.7 cm
- 1-year warranty
- Designed For
- EliteBook Folio 9470m
- Laptop battery
- Long life
- Technology
- 6-cell Lithium Ion
- Voltage Provided
- 11.1 V
- Capacity
- 5400 mAh
- Recharge Time
- 3.5 hours
- Limited warranty - 1 year
- 0 °C
- 45 °C
- 32 cm
- 21.3 cm
- 0.7 cm
- 780 g
- Designed For
- HP EliteBook Folio 9470m
