HP BA06 Long Life Battery (Secondary Battery Slice)
Quicklinx: 9RBSWS00 Mfr#: H4Q48AA
The HP BA06 Long Life Battery is a slice battery that slides onto the bottom of the HP EliteBook Folio 9470m Notebook PC to help you be productive longer than using the primary battery alone.
HP BA06 - laptop battery - Li-Ion - 5400 mAh
Laptop battery
780 g
Long life - Lithium Ion 6-cell - 5400 mAh
Batteries Qty
1
32 cm x 21.3 cm x 0.7 cm
1-year warranty
Laptop battery
Long life
Quantity
1
6-cell Lithium Ion
Voltage Provided
11.1 V
5400 mAh
Recharge Time
3.5 hours
Limited warranty - 1 year
45 °C
32 cm
21.3 cm
0.7 cm
780 g
