HP B300 Mounting Bracket
Quicklinx: D54WWS00 Mfr#: 2DW53AA
HP B300 Mounting kit and Bracket for LCD display or Thin Client including EliteDisplay E233
  • Make room and keep things tidy
    Maximize your available work area with a single-footprint solution. Simply attach the bracket to the back of your display's stand, and your PC platform to the bracket. It's that easy! Reduce cable clutter with short USB A to B and DisplayPort cables.
  • Work comfortably
    Retain the comfort features of your 2017 or 2018 HP Elite Display or HP Z Display. The bracket doesn't interfere with the monitor's height adjustment, tilt, swivel or pivot settings.
  • Rest easy
    Get the reassurance of a one-year limited warranty.
HP B300 mounting kit - for LCD display / thin client
Mounting kit
Mounting Components
Mount bracket
11.506 cm x 5.182 cm x 24.638 cm
318 g
Recommended Use
VESA Mounting Interface
100 x 100 mm
Package Content
DisplayPort cable, USB cable, 4 x 6 mm screws, 4 x 10 mm screws, security lock
HP 260 G3, 260 G4, t310 G2, t430, t430 v2, t540; Elite 600 G9, 800 G9, t655; EliteDesk 705 G5; EliteDisplay E223d Docking Monitor, E233; Pro 260 G9, t550; ProDesk 400 G5 (mini desktop), 405 G4, 405 G8, 600 G4
11.506 cm
5.182 cm
24.638 cm
318 g
Package Content
AV Furniture
Mounting kit
Mounting Components
Mount bracket
Recommended Use
100 x 100 mm
HP 260 G3, 260 G4, t310 G2, t430, t430 v2, t540 , HP Elite 600 G9, 800 G9, t655 , HP EliteDesk 705 G5 , HP EliteDisplay E223d Docking Monitor, E233 , HP Pro 260 G9, t550 , HP ProDesk 400 G5 (mini desktop), 405 G4, 405 G8, 600 G4
