HP B300 Mounting kit and Bracket for LCD display or Thin Client including EliteDisplay E233
Make room and keep things tidy
Maximize your available work area with a single-footprint solution. Simply attach the bracket to the back of your display's stand, and your PC platform to the bracket. It's that easy! Reduce cable clutter with short USB A to B and DisplayPort cables. -
Work comfortably
Retain the comfort features of your 2017 or 2018 HP Elite Display or HP Z Display. The bracket doesn't interfere with the monitor's height adjustment, tilt, swivel or pivot settings. -
Rest easy
Get the reassurance of a one-year limited warranty.
- HP B300 - mounting kit - for LCD display / thin client
- Product Type
- Mounting kit
- Mounting Components
- Mount bracket
- 11.506 cm x 5.182 cm x 24.638 cm
- 318 g
- Recommended Use
- LCD display / thin client
- VESA Mounting Interface
- 100 x 100 mm
- Package Content
- DisplayPort cable, USB cable, 4 x 6 mm screws, 4 x 10 mm screws, security lock
- Designed For
- HP 260 G3, 260 G4, t310 G2, t430, t430 v2, t540; Elite 600 G9; EliteDesk 705 G5; EliteDisplay E223d Docking Monitor, E233; ProDesk 400 G5 (mini desktop), 405 G4, 405 G8, 600 G4
- 11.506 cm
- 5.182 cm
- 24.638 cm
- 318 g
- Package Content
AV Furniture
- Mounting kit
- Mount bracket
- Recommended Use
- 100 x 100 mm
- Designed For
- HP 260 G3, 260 G4, t310 G2, t430, t430 v2, t540 , HP Elite 600 G9 , HP EliteDesk 705 G5 , HP EliteDisplay E223d Docking Monitor, E233 , HP ProDesk 400 G5 (mini desktop), 405 G4, 405 G8, 600 G4
