Drive your everyday PC, Web conferencing, and video or photo content to up to two displays from one card with the AMD Radeon R9 350 2GB PCIe x16 Card.
Get dual-display support plus enhanced HDCP content security from the Dual-Link DVI and DisplayPort connectors. Conveniently expand your connectivity to HDMI, DVI, and VGA displays from the DisplayPort connector with optional adapters.
Experience peak bandwidth support from the full 16-lane PCIe 3.0 bus. Eliminate the need to share PC system memory with 2 GB of dedicated GDDR5 memory.
Work with your familiar tools with a card that supports OpenGL 4.3 and DirectX 12 applications.
Flexible connectivity
Get dual-display support plus enhanced HDCP content security from the Dual-Link DVI and DisplayPort connectors. Conveniently expand your connectivity to HDMI, DVI, and VGA displays from the DisplayPort connector with optional adapters. -
Smart memory
Experience peak bandwidth support from the full 16-lane PCIe 3.0 bus. Eliminate the need to share PC system memory with 2 GB of dedicated GDDR5 memory. -
Broad application support
- AMD Radeon R9 350 - graphics card - Radeon R9 350 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- AMD Radeon R9 350
- Memory
- 2 GB GDDR5
- Core Clock
- 925 MHz
- Effective Memory Clock
- 1125 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Max Monitors Supported
- 4
- Interfaces Details
- DVI-I (dual link) , 2 x DisplayPort , VGA - with adapter
- API Supported
- OpenCL 1.2, DirectX 11.1, OpenGL 4.3
- 1-year warranty
- Designed For
- HP 4000 Pro; Business Desktop dc5800; EliteDesk 705 G2 (micro tower), 705 G3 (micro tower), 800 G2 (tower); ProDesk 400 G3 (micro tower), 490 G3 (micro tower), 600 G2 (micro tower)
- Graphics card
- Bus Type
- Graphics Engine
- AMD Radeon R9 350
- Core Clock
- 925 MHz
- Max Resolution
- 4096 x 2160 at 60 Hz
- 4
- API Supported
- AMD Unified Video Decoder (UVD)
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 1125 MHz
- Bus Width
- 128-bit
- OS Required
- Microsoft Windows 7 (32/64 bits), Windows 8.1 64-bit Edition, Windows 10 64-bit Edition
- Additional Requirements
- Adjacent PCI slot
- 58 Watt
- UL, VCCI, BSMI, ACA, CISPR, ICES, KC
- Limited warranty - 1 year
- Designed For
- HP EliteDesk 705 G2 (micro tower), 705 G3 (micro tower), 800 G2 (tower) , HP ProDesk 400 G3 (micro tower), 490 G3 (micro tower), 600 G2 (micro tower) , HP Compaq 4000 Pro , HP Compaq Business Desktop dc5800
