HP Adjustable Dual Monitor Stand
Quicklinx: 7DFGWS00 Mfr#: AW664AA
Accessory Type: Stand
Hurry, only 1 left in stock!
£148.12 ex VAT
£177.74 inc VAT
Express delivery Order within the next 19 hours for delivery on Tuesday
The HP Adjustable Dual Display Stand allows you to use two displays to maximize your productivity and optimize efficiency. Either or both displays can be rotated to landscape or portrait orientation, and the stand is depth-, height- , tilt-, and angle-adjustable so you can view both screens at eye-level as well as slightly facing each other, letting you track multiple applications and information sources at the same time. Integrated base rollers let you rotate the stand so you can more easily share your work.
HP Adjustable Dual Display Stand - stand
Stand
Mounting Components
Stand base
50 cm x 35.5 cm x 40 cm
Adjustments
Tilt
5.6 kg
Recommended Use
2 LCD displays
Recommended Display Size
Up to 24"
VESA Mounting Interface
HP 24X G6, 25X G7; Chromebook 11 G6, 11 G7, 11A G6, 14 G5, 14A G5; Chromebook x360; EliteBook 1040 G4, 10XX G1, 735 G5, 745 G5, 755 G5, 830 G5, 840 G5, 840r G4, 850 G5; EliteBook x360; ProBook 430 G6, 44X G6, 45X G5, 45X G6, 64X G4, 650 G4; ProBook x360; Spectre x360; Stream Pro 11 G4; ZBook x2
50 cm
35.5 cm
40 cm
5.6 kg
AV Furniture
Stand
Mounting Components
Stand base
Recommended Use
2 LCD displays
Cable Management
Integrated cable management
Up to 24"
Adjustments
Tilt
Adjustable height
Compaq LA2405wg , HP 240 G6, 245 G6, 250 G4, 250 G5, 250 G6, 250 G7, 255 G4, 255 G5, 255 G6, 255 G7, 350 G2, L2105tm Touchscreen, LA1905wg, LA2205wg, LE1851w, LE1901w, LE1901wm, LE2001w, LE2001wm, LE2201w, LP1965, LP2065, LP2275w, LP2475w, ZR22w, ZR24w , HP Chromebook 11 G4, 11 G5, 11 G6, 11 G7, 11A G6, 13 G1, 14 G4, 14 G5, 14A G5 , HP Chromebook x360 11 G1 (Education Edition), 11 G2, 14 G1 , HP EliteBook 1030 G1, 1040 G3, 1040 G4, 1050 G1, 725 G3, 725 G4, 735 G5, 745 G3, 745 G4, 745 G5, 755 G2, 755 G3, 755 G4, 755 G5, 820 G3, 820 G4, 830 G5, 840 G2, 840 G3, 840 G4, 840 G5, 840r G4, 8470p, 850 G2, 850 G3, 850 G4, 850 G5, 8570p , HP EliteBook Folio 1020 G1, 1040 G1, 1040 G2, 9470m, G1 , HP EliteBook Revolve 810 G1 Tablet, 810 G3 Tablet , HP EliteBook x360 1020 G2, 1030 G2, 1030 G3, 1040 G5, 830 G5 , HP Folio 13-1000ea, 13-1000eo, 13-1008tu, 13-1010ef, 13-1016tu, 13-1051nr , HP Folio 13 , HP ProBook 11 G1 (Education Edition), 430 G3, 430 G4, 430 G5, 430 G6, 440 G3, 440 G4, 440 G5, 440 G6, 445 G6, 450 G2, 450 G3, 450 G4, 450 G5, 450 G6, 4540s, 455 G3, 455 G4, 455 G5, 455 G6, 470 G3, 470 G4, 470 G5, 640 G1, 640 G2, 640 G3, 640 G4, 645 G1, 645 G2, 645 G3, 645 G4, 6470b, 6475b, 650 G1, 650 G2, 650 G3, 650 G4, 655 G1, 655 G2, 655 G3, 6570b , HP ProBook x360 11 G2, 11 G3, 11 G4, 440 G1 , HP Spectre x360 15-ch006tx , HP Stream Pro 11 G3, 11 G4 (Education Edition) , HP x360 310 G2 , HP ZBook , HP ZBook x2 G4 Detachable Workstation , HP Compaq L2105tm, LA1751g, LA1951G, LA2205wg, LA22f, LA2405wg, LE1711, LE19f
HP Adjustable Dual Monitor Stand Bundle deal on HP Adjustable Dual Monitor Stand
£247.88
Brand: HP
Price Range Ex VAT: 100 - 150
