The HP Adjustable Dual Display Stand allows you to use two displays to maximize your productivity and optimize efficiency. Either or both displays can be rotated to landscape or portrait orientation, and the stand is depth-, height- , tilt-, and angle-adjustable so you can view both screens at eye-level as well as slightly facing each other, letting you track multiple applications and information sources at the same time. Integrated base rollers let you rotate the stand so you can more easily share your work.
- HP Adjustable Dual Display Stand stand - for 2 LCD displays
- Product Type
- Stand
- Mounting Components
- Stand base
- 50 cm x 35.5 cm x 40 cm
- Adjustments
- Tilt
- 5.6 kg
- Recommended Use
- 2 LCD displays
- Recommended Display Size
- Up to 24"
- VESA Mounting Interface
- 50 cm
- 35.5 cm
- 40 cm
- 5.6 kg
AV Furniture
- Stand
- Stand base
- Recommended Use
- 2 LCD displays
- Cable Management
- Integrated cable management
- Up to 24"
- Adjustments
- Tilt
- Adjustable height
