HP Adjustable Dual Monitor Stand
Quicklinx: 7DFGWS00 Mfr#: AW664AA
The HP Adjustable Dual Display Stand allows you to use two displays to maximize your productivity and optimize efficiency. Either or both displays can be rotated to landscape or portrait orientation, and the stand is depth-, height- , tilt-, and angle-adjustable so you can view both screens at eye-level as well as slightly facing each other, letting you track multiple applications and information sources at the same time. Integrated base rollers let you rotate the stand so you can more easily share your work.
HP Adjustable Dual Display Stand - stand
Stand
Mounting Components
Stand base
50 cm x 35.5 cm x 40 cm
Adjustments
Tilt
5.6 kg
Recommended Use
2 LCD displays
Recommended Display Size
Up to 24"
VESA Mounting Interface
HP 245 G7, 340S G7, 34X G5, 470 G7; Chromebook 11 G8, 11A G8, 14 G6; Chromebook Enterprise 14 G6; Chromebook Enterprise x360; Chromebook x360; EliteBook 735 G6, 745 G6; EliteBook x360; Mobile Thin Client mt45; ProBook 430 G7, 44X G7, 455r G6, 45X G7, 640 G5, 650 G5; ProBook x360; ZBook 15 G6, 17 G6
50 cm
35.5 cm
40 cm
5.6 kg
AV Furniture
Stand
Mounting Components
Stand base
Recommended Use
2 LCD displays
Cable Management
Integrated cable management
Up to 24"
Adjustments
Tilt
Adjustable height
HP 240 G6, 245 G6, 245 G7, 250 G4, 250 G5, 250 G6, 250 G7, 255 G4, 255 G5, 255 G6, 255 G7, 340 G5, 340S G7, 348 G5, 470 G7 , HP Chromebook 11 G4, 11 G5, 11 G6, 11 G7, 11 G8, 11A G6, 11A G8, 13 G1, 14 G4, 14 G5, 14 G6, 14A G5 , HP Chromebook Enterprise 14 G6 , HP Chromebook Enterprise x360 14E G1 , HP Chromebook x360 11 G1 (Education Edition), 11 G2, 11 G3, 14 G1 , HP EliteBook 1030 G1, 1040 G3, 1040 G4, 1050 G1, 725 G3, 725 G4, 735 G5, 735 G6, 745 G3, 745 G4, 745 G5, 745 G6, 755 G3, 755 G4, 755 G5, 820 G3, 820 G4, 830 G5, 830 G6, 840 G3, 840 G4, 840 G5, 840 G6, 840r G4, 850 G3, 850 G4, 850 G5, 850 G6 , HP EliteBook Folio 1020 G1, G1 , HP EliteBook x360 1020 G2, 1030 G2, 1030 G3, 1030 G4, 1040 G5, 1040 G6, 830 G5, 830 G6 , HP Mobile Thin Client mt45 , HP ProBook 11 G1 (Education Edition), 430 G3, 430 G4, 430 G5, 430 G6, 430 G7, 440 G3, 440 G4, 440 G5, 440 G6, 440 G7, 445 G6, 445 G7, 445r G6, 450 G3, 450 G4, 450 G5, 450 G6, 450 G7, 455 G3, 455 G4, 455 G5, 455 G6, 455 G7, 455r G6, 470 G3, 470 G4, 470 G5, 640 G2, 640 G3, 640 G4, 640 G5, 645 G2, 645 G3, 645 G4, 650 G2, 650 G3, 650 G4, 650 G5, 655 G2, 655 G3 , HP ProBook x360 11 G2, 11 G3, 11 G4, 11 G5, 11 G6, 440 G1 , HP Spectre x360 15-ch006tx , HP Stream Pro 11 G3, 11 G4 (Education Edition) , HP x360 310 G2 , HP ZBook 14 G2 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15 G5 Mobile Workstation, 15 G6 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, 17 G5 Mobile Workstation, 17 G6 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
