HP AC Adapter 19.5V 45W Includes Power Cable
Quicklinx: CMP5WS00 Mfr#: 740015-003
Smart Adapter can enhance your productivity by powering your notebook while plugged in, as well as charging your battery so that you can take your notebook with you when you unplug. HP Smart Adapter also features integrated surge protection to protect against power fluctuations that can damage your notebook. HP Smart Adapter helps you save on equipment, power consumption costs and travel.
HP Smart - power adapter - 45 Watt
Power adapter - no Power Factor Correction (PFC) - external
Input Voltage
AC
Output Voltage
19.5 V
Power Capacity
45 Watt
Output connectors
Power DC jack 4.5 mm
Pavilion Laptop 13, 14, 15, 17
Input Voltage
AC
Output Voltage
19.5 V
Max Electric Current
2.31 A
Power Capacity
45 Watt
HP Pavilion Laptop 14-ab021la, 14-ab155la, 15-ab002ns, 15-ab004la, 15-ab027cl, 15-ab063cl, 15-ab066na, 15-ab088ca, 15-ab090na, 15-ab095na, 15-ab101ax, 15-ab102ng, 15-ab107nf, 15-ab107ng, 15-ab110nl, 15-ab111la, 15-ab112ns, 15-ab113nl, 15-ab114ng, 15-ab114ns, 15-ab115ng, 15-ab115ns, 15-ab116la, 15-ab116ns, 15-ab117ns, 15-ab122nc, 15-ab126la, 15-ab126nl, 15-ab127na, 15-ab127nc, 15-ab142cy, 15-ab146na, 15-ab150sa, 15-ab153no, 15-ab153nr, 15-ab155nw, 15-ab155sa, 15-ab199cy, 15-ab201ns, 15-ab202ng, 15-ab202nt, 15-ab203nt, 15-ab204cy, 15-ab205cy, 15-ab206cy, 15-ab207cy, 15-ab208nf, 15-ab208nt, 15-ab209nt, 15-ab211nh, 15-ab211nt, 15-ab214nt, 15-ab215nt, 15-ab216ns, 15-ab217cy, 15-ab217nt, 15-ab218nt, 15-ab219cy, 15-ab219nt, 15-ab220cy, 15-ab220no, 15-ab220nt, 15-ab223ng, 15-ab230nw, 15-ab232ng, 15-ab238tu, 15-ab243cl, 15-ab245nf, 15-ab247ng, 15-ab248ng, 15-ab249ng, 15-ab249nl, 15-ab250ng, 15-ab251, 15-ab251nl, 15-ab251nr, 15-ab267nr, 15-ab271nd, 15-ab276nf, 15-ab278nw, 15-ab293cl, 15-ab294nb, 15-ab506na, 15-ab511na, 15-ab513na, 15-ab536nz, 15-ab562nz, 15-ab564nz, 15-ab566tx, 15-ab582nz, 15-n210es, 15-n214es, 15-n218es, 15-p006ns, 15-p007ns, 15-p010ax, 15-p015st, 15-p016ax, 15-p030nz, 15-p050no, 15-p095no, 15-p202nt, 15-p207nt, 15-p210nt, 15-p211nt, 15-p212nt, 15-p219ns, 15-p220nt, 15-p233cl, 15-p263nr, 17-f203ns, 17-f207ns, 17-f210nt, 17-f233cl, 17-g003ns, 17-g022nf, 17-g061us, 17-g102ni, 17-g103nh, 17-g105ns, 17-g108nc, 17-g112nc, 17-g114nl, 17-g117nf, 17-g120na, 17-g125cy, 17-g126cy, 17-g127cl, 17-g128cy, 17-g128ds, 17-g130cy, 17-g130na, 17-g131na, 17-g134ds, 17-g135na, 17-g143nb, 17-g147cy, 17-g148ng, 17-g149ds, 17-g152nw, 17-g153nh, 17-g155nl, 17-g159nf, 17-g164ng, 17-g167cl, 17-g172nd, 17-g173ca, 17-g173nf, 17-g180nf, 17-g183nd, 17-g185nf, 17-g186cy, 17-g186nf, 17-g188cy, 17-g189cy, 17-g192dx, 17-g193cy, 17-g194cy, 17-g195cy, 17-g198cy, 17-g199cy, 17-g201cy, 17-g202cy, 17-g216cy, 17-g218cy, 17-g219cy, 17-g221cy
