HP 971 XL High Yield Magenta Original Ink Cartridge
Quicklinx: 8KHWWS00 Mfr#: CN627AE
Type: Ink Cartridge
Technology: Ink-Jet
More than 50 In Stock
£88.72 ex VAT
£106.46 inc VAT
HP 971XL Magenta Officejet Ink Cartridge produces professional-quality colour documents for great value, while allowing workgroups to save time creating consistent, durable prints.
  • Designed to work the first time, every time
    Be assured that Original HP Cartridges will consistently deliver quality results and premium performance.
  • Quality prints you can take pride in
    Experience premium print quality with Original HP Cartridges designed for vibrant color, crisp text, and rich blacks for big impact.
  • The environmental choice
    Print with confidence – Original HP Cartridges designed with the planet in mind for easy recycling and less waste.
  • Better together. Better results
    Original HP Cartridges are the only cartridges precisely developed with HP printers for reliable quality, results, and consistent performance.
  • Original HP Cartridges fast and high-volume printing
    Expect peak performance from Original HP pigment inks – specially formulated for the HP OfficeJet Pro X series.
  • Quality prints until the end of the cartridge
    Maintain quality until the last drop, using built-in cartridge intelligence.
HP 971XL - High Yield - magenta - original - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
Printing Colour
Magenta
Cartridge Yield
High Yield
Yield
Up to 6600 pages
EMEA
Compatible with
Officejet Pro X451dn, X451dw, X476dn MFP, X476dw MFP, X551dw, X576dw MFP
Shipping Weight
0.2 kg
EMEA
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
Magenta
Included Qty
1-pack
Cartridge Yield
High Yield
Yield
Up to 6600 pages
Compatible with
HP Officejet Pro X451dn, X451dw, X476dn MFP, X476dw MFP, X551dw, X576dw MFP
Type: Ink Cartridge
Technology: Ink-Jet
Brand: HP
