HP 90W Smart AC Adapter
Quicklinx: BKSHWS00 Mfr#: H6Y90AA#ABU
Device Type: Laptop
More than 50 in stock
£35.09 ex VAT
£42.10 inc VAT
Provide optimal power and help offset power fluctuations to your HP notebook with a HP 90W Smart AC Adapter. Now available with a new right-angled (90°) connector that reduces cable stress and an optional 4.5mm to 7.4mm conversion dongle. As a replacement or back-up adapter, be prepared with the right connection.
  • Controlled and efficient flow
    Operate with confidence with optimal performance using smart-pin technology and reduce the risk of power surges, while drawing only minimal power as needed.
  • Connection for today and yesterday
    Connection versatility with a specially designed dongle allowing for simple conversion from the new standard 4.5mm connector to HP predecessor notebooks with 7.4mm connectors.
  • The perfect right turn
    Tight access made convenient – the new right-angled (90°) 4.5mm connector allows for connecting in limited spaces and reduces cord bending providing better cable management and longevity.
HP Smart AC Adapter - power adapter - 90 Watt
Power adapter - external
370 g
English / United Kingdom
Output Voltage
19 V
Power Capacity
90 Watt
4.5mm to 7.4mm power DC dongle
12.7 cm x 5 cm x 2.9 cm
Chromebook 11 G5, 13 G1; Chromebox G2; EliteBook 725 G4, 735 G5, 745 G4, 745 G5, 755 G4, 755 G5, 820 G4, 830 G5, 840 G4, 840 G5, 840r G4, 850 G4, 850 G5; EliteBook x360; ProBook 430 G4, 440 G4, 445 G6, 455 G6, 45X G4, 470 G4, 640 G5, 64X G3, 64X G4, 650 G4, 65X G3; Stream Pro 11 G4; ZBook 15u G4
Output Voltage
19 V
Power Capacity
90 Watt
Power cable
Over voltage protection
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
20 - 80%
12.7 cm
5 cm
2.9 cm
370 g
Shipping Weight
0.7 kg
HP 250 G1, 250 G2, 250 G3, 250 G5, 255 G1, 255 G2, 255 G3, 255 G5, 350 G1, 350 G2, 355 G2 , HP Chromebook 11 G4, 11 G5, 13 G1, 14, 14 G4 , HP Chromebox G2 , HP EliteBook 1030 G1, 1040 G3, 720 G1, 720 G2, 725 G2, 725 G3, 725 G4, 735 G5, 740 G1, 740 G2, 745 G2, 745 G3, 745 G4, 745 G5, 750 G1, 750 G2, 755 G2, 755 G3, 755 G4, 755 G5, 820 G1, 820 G2, 820 G3, 820 G4, 830 G5, 840 G1, 840 G2, 840 G3, 840 G4, 840 G5, 840r G4, 850 G1, 850 G2, 850 G3, 850 G4, 850 G5 , HP EliteBook Folio 1020 G1, 1040 G1, 1040 G2, 9480m , HP EliteBook Revolve 810 G1 Tablet, 810 G2 Tablet, 810 G3 Tablet , HP EliteBook x360 1020 G2, 1030 G2 , HP Pro x2 612 G1 , HP ProBook 430 G1, 430 G2, 430 G3, 430 G4, 4340s, 440 G3, 440 G4, 445 G6, 450 G0, 450 G1, 450 G2, 450 G3, 450 G4, 4540s, 4545s, 455 G1, 455 G3, 455 G4, 455 G6, 470 G0, 470 G1, 470 G2, 470 G3, 470 G4, 4740s, 640 G1, 640 G2, 640 G3, 640 G4, 640 G5, 645 G1, 645 G2, 645 G3, 645 G4, 650 G1, 650 G2, 650 G3, 650 G4, 655 G1, 655 G2, 655 G3 , HP Spectre x2 13 , HP Spectre x2 Pro 13 , HP Stream Pro 11 G4 (Education Edition) , HP x360 310 G1, 310 G2 , HP ZBook 14 G2 Mobile Workstation, 14 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation
HP 90W Smart AC Adapter Bundle deal on HP 90W Smart AC Adapter
£126.63
Device Type: Laptop
Brand: HP
Price Range Ex VAT: 0 - 50
