Provide optimal power and help offset power fluctuations to your HP notebook with a HP 90W Smart AC Adapter. Now available with a new right-angled (90°) connector that reduces cable stress and an optional 4.5mm to 7.4mm conversion dongle. As a replacement or back-up adapter, be prepared with the right connection.
Controlled and efficient flow
Operate with confidence with optimal performance using smart-pin technology and reduce the risk of power surges, while drawing only minimal power as needed. -
Connection for today and yesterday
Connection versatility with a specially designed dongle allowing for simple conversion from the new standard 4.5mm connector to HP predecessor notebooks with 7.4mm connectors. -
The perfect right turn
Tight access made convenient – the new right-angled (90°) 4.5mm connector allows for connecting in limited spaces and reduces cord bending providing better cable management and longevity.
- HP Smart AC Adapter - power adapter - 90 Watt
- Power adapter - external
- 370 g
- Localisation
- English / United Kingdom
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Included Accessories
- 4.5mm to 7.4mm power DC dongle
- 12.7 cm x 5 cm x 2.9 cm
- Designed For
- HP 25X G1; ProBook 430 G1, 430 G2, 430 G3, 430 G4, 440 G3, 440 G4, 445 G6, 445r G6, 450 G0, 450 G2, 455 G6, 455r G6, 45X G1, 45X G3, 45X G4, 470 G0, 470 G1, 470 G2, 470 G3, 470 G4, 640 G5, 64X G1, 64X G2, 64X G3, 64X G4, 650 G4, 650 G5, 65X G1, 65X G2, 65X G3; ZBook 14, 14 G2, 15u G2, 15u G3, 15u G4
- Localisation
- Output Voltage
- 19 V
- Power Capacity
- 90 Watt
- Cables Included
- Power cable
- Over voltage protection
- CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
- 0 °C
- 40 °C
- 20 - 80%
- 12.7 cm
- 5 cm
- 2.9 cm
- 370 g
- Shipping Weight
- 0.7 kg
- Designed For
- HP 245 G1 Notebook, 24-df0076na, 24-df0099nf, 24-df0181nf, 24-df1011nb, 24-df1030na, 24-df1032ns, 24-df1036ns, 24-df1038nl, 24-df1303ng, 250 G1 Notebook, 250 G2 Notebook, 250 G3 Notebook, 250 G5 Notebook, 255 G1 Notebook, 255 G2 Notebook, 255 G3 Notebook, 255 G5 Notebook, 340 G2 Notebook, 340 G5 Notebook, 348 G5 Notebook, 350 G1 Notebook, 350 G2 Notebook, 355 G2 Notebook , HP EliteBook 1030 G1 Notebook, 1040 G3 Notebook, 720 G1 Notebook, 720 G2 Notebook, 725 G2 Notebook, 725 G3 Notebook, 725 G4 Notebook, 735 G5 Notebook, 740 G1 Notebook, 740 G2 Notebook, 745 G2 Notebook, 745 G3 Notebook, 745 G4 Notebook, 745 G5 Notebook, 750 G1 Notebook, 750 G2 Notebook, 755 G2 Notebook, 755 G3 Notebook, 755 G4 Notebook, 755 G5 Notebook, 820 G1 Notebook, 820 G2 Notebook, 820 G3 Notebook, 820 G4 Notebook, 830 G5 Notebook, 840 G1 Notebook, 840 G2 Notebook, 840 G3 Notebook, 840 G4 Notebook, 840 G5 Notebook, 840r G4 Notebook, 850 G1 Notebook, 850 G2 Notebook, 850 G3 Notebook, 850 G4 Notebook, 850 G5 Notebook , HP EliteBook x360 1020 G2 Notebook, 1030 G2 Notebook , HP ProBook 430 G1 Notebook, 430 G2 Notebook, 430 G3 Notebook, 430 G4 Notebook, 440 G3 Notebook, 440 G4 Notebook, 445 G6 Notebook, 445r G6 Notebook, 450 G0 Notebook, 450 G1 Notebook, 450 G2 Notebook, 450 G3 Notebook, 450 G4 Notebook, 455 G1 Notebook, 455 G3 Notebook, 455 G4 Notebook, 455 G6 Notebook, 455r G6 Notebook, 470 G0 Notebook, 470 G1 Notebook, 470 G2 Notebook, 470 G3 Notebook, 470 G4 Notebook, 640 G1 Notebook, 640 G2 Notebook, 640 G3 Notebook, 640 G4 Notebook, 640 G5 Notebook, 645 G1 Notebook, 645 G2 Notebook, 645 G3 Notebook, 645 G4 Notebook, 650 G1 Notebook, 650 G2 Notebook, 650 G3 Notebook, 650 G4 Notebook, 650 G5 Notebook, 655 G1 Notebook, 655 G2 Notebook, 655 G3 Notebook , HP Spectre x360 Laptop 15-eb1003nl, 15-eb1097nr , HP ZBook 14 G2 Mobile Workstation, 14 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation
