HP 8GB DDR4-2400 DIMM
Quicklinx: CTBFWS00 Mfr#: Z9H60AT
HP - DDR4 - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - 1.2 V - unbuffered - non-ECC - promo - for EliteDesk 800 G3 (DIMM); ProDesk 400 G4, 600 G3 (DIMM)
  • Flexible, fast scalability
    Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs.
  • Supported by HP
    Protect your investment with the same world-class HP limited warranty you get for your PC.
HP - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - unbuffered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Unbuffered
Voltage
1.2 V
HP Z9H60AT
Pricing Type
Promo
8 GB
Upgrade Type
System specific
HP Z9H60AT
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Non-ECC
Unbuffered
Voltage
1.2 V
Pricing Type
Promo
HP EliteDesk 800 G3 (DIMM) , HP ProDesk 400 G4, 600 G3 (DIMM)
