Product
HP 8GB 2400MHz DDR4 Memory
Quicklinx: CKLDWS00 Mfr#: Z4Y85AA
Boost the capabilities of your HP Business Notebook PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
Flexible, fast scalability
Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
HP-tested
Ensure that all of your memory characteristics match by upgrading with HP-branded memory that’s been tested for seamless system-level integration with HP Business Notebook PCs.
Supported by HP
Protect your investment with a one-year limited warranty.
  • Flexible, fast scalability
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP Business Notebook PCs.
  • Supported by HP
HP - DDR4 - 8 GB - SO-DIMM 260-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Unbuffered
Voltage
1.2 V
HP Z4Y85AA
1 year warranty
HP 24X G6, 25X G6; EliteBook 735 G5, 745 G5, 755 G4, 755 G5, 820 G4, 830 G5, 840 G4, 840 G5, 840r G4, 850 G4, 850 G5; ProBook 430 G5, 440 G5, 450 G5, 450 G6, 470 G5, 64X G3, 64X G4, 650 G4, 65X G3; ZBook 14u G4, 14u G5, 15 G4, 15u G4, 15u G5, 15v G5, 17 G4, Studio G4, Studio G5, Studio x360 G5
8 GB
Upgrade Type
System specific
HP Z4Y85AA
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Unbuffered
Voltage
1.2 V
1 year warranty
HP 240 G6, 245 G6, 250 G5, 250 G6, 255 G5, 255 G6 , HP EliteBook 725 G4, 735 G5, 745 G4, 745 G5, 755 G4, 755 G5, 820 G3, 820 G4, 830 G5, 840 G3, 840 G4, 840 G5, 840r G4, 850 G3, 850 G4, 850 G5 , HP ProBook 430 G3, 430 G4, 430 G5, 440 G3, 440 G4, 440 G5, 450 G3, 450 G4, 450 G5, 450 G6, 455 G3, 455 G4, 470 G3, 470 G4, 470 G5, 640 G2, 640 G3, 640 G4, 645 G3, 645 G4, 650 G2, 650 G3, 650 G4, 655 G3 , HP ZBook 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 15 G3 Mobile Workstation, 15 G4 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15v G5 Mobile Workstation, 17 G3 Mobile Workstation, 17 G4 Mobile Workstation, Studio G3 Mobile Workstation, Studio G4 Mobile Workstation, Studio G5 Mobile Workstation, Studio x360 G5 Mobile Workstation
