Product
HP 820 G2 Intel Core i5-5200U 4GB 500GB 12.5" Windows 7 Professional 64-bit
CLEARANCE Was £694 Now £660 Save £34!
Quicklinx: B9RFWS00 Mfr#: L8T39ET#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • Bluetooth 4.0
  • IEEE 802.11n
in stock
£552.99 ex VAT
£663.58 inc VAT
Ultra-thin and lightweight, the HP 820 G2 is the perfect portable companion for business users; and with enhanced security and management features, you can enjoy reliable and long-lasting performance.
Enjoy plenty of storage for your largest files without compromising on speed thanks to the HP EliteBook 820’s 4GB RAM and 500GB hard drive. The powerful Intel Core i5 processor features turbo boost technology and users can access the Internet wherever they are with the integrated wireless technology while the Bluetooth 4.0 ensures swift data transfer.
The HP 820 also offers stunning image quality in HD resolution, while the stereo speakers and microphones support high definition audio – handy whether you’re making a business call or listening to your favourite music.
Take advantage of the heightened security features, including SmartCard reader, putting you in full control and minimising the risk of data theft.
Using it in the office? Simply connect your HP laptop to a docking station and you’ll be able to seamlessly continue working on the same files – with the added bonus of having a larger desktop monitor.
  • Portable powerhouse
    The HP EliteBook 820 with a starting weight of less than 1,36 kg/3 lbs is ideal for travel and use in enterprise environments. Stay productive with Windows 8.1 and powerful 5th Gen Intel Core processors.
  • Equipped for productivity
    Leave dongles behind with a drop-jaw Ethernet port, VGA port, and DisplayPort for key connections to all your devices. Stay connected with co-workers and customers with HP Connection Manager and optional Qualcomm Gobi 4G LTE.
  • Road ready
    Never fear bumps and minor spills. The thin, light, and stylish HP EliteBook 820 endures HP's Total Test Process and passes rigorous MIL-STD 810G testing.
  • Solid security and manageability
    All the features IT expects including an expanded security portfolio and manageability tools to fulfill the needs for your business.
HP EliteBook 820 G2 - 12.5" - Core i5 5200U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Intel Core i5 (5th Gen) 5200U / 2.2 GHz (2.7 GHz) / 3 MB Cache
4 GB DDR3L (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
No optical drive
Display
12.5" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 5500
Input Device
Pointing stick
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, SmartCard reader
31 cm x 21.53 cm x 2.1 cm
1.34 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years , Limited warranty - battery - 3 years
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro) + Windows 8.1 Pro Licence - English
Processor / Chipset
CPU
Max Turbo Speed
2.7 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Intel Turbo Boost Technology 2.0
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR3L SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 7200 rpm
Display
12.5"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
200 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 1280 x 720
Sound
Stereo speakers, two microphones
Codec
IDT 92HD91
High Definition Audio, DTS Studio Sound, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Half Mini Card
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I218-LM
Gobi Technology, Miracast
IEEE 802.2, IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.3az
3-cell lithium polymer
46 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
3 x USB 3.0 , DisplayPort , Headphone/microphone combo jack , LAN , Dock
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Cyberlink PowerDVD, Adobe Flash Player, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, Foxit PhantomPDF Express, HP Mobile Connect, HP Systems Software Manager (free download), HP PageLift, HP UEFI System Diagnostics, HP Wireless Hotspot, Getting Started guide with Windows 8, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP Driver Packs, LANDesk Management Suite (free download), HP Device Access Manager
Case Material
Magnesium-aluminum alloy
Dockable
Security
Power-on password, HP Disk Sanitizer, HP 3D DriveGuard, HP DuraFinish, HP DuraKeys, HP SpareKey, HP File Sanitizer, HP DisplaySafe, HP BIOS Protection, BIOS Absolute Persistence, HP SureStart, HP Drive Encryption, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security, HP Roaming Alert, Intel My WiFi Technology, 1 USB 3.0 charging port
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
ACPI, CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, RoHS, WEEE, EAL 4+, A-Tick, ICES, KC, CIT
Localization
1.34 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
