Step up to workstation performance
Take performance up a notch with plenty of configurations and expandability. With NVIDIA GeForce & Quadro options, you can pick the perfect GPU for the job. Plus, multiple expansion slots provide plenty of room to accommodate your evolving needs. -
Software certified
Work with confidence knowing your desktop is certified for your most critical applications. We've worked closely with leading software providers like Autodesk and SolidWorks to help ensure seamless and reliable performance at every stage of your workflow. -
HP's most secure and manageable workstations
Get powerful protection from evolving malware threats with self-healing, hardware-enforced security solutions like HP Sure Start Gen4 which protects against BIOS attacks. Plus, easily manage multiple devices with the HP Manageability Integration Kit Gen2 .
- HP EliteDesk 800 G4 - tower - Core i7 8700 3.2 GHz - vPro - 16 GB - SSD 512 GB - UK
- Personal computer - tower
- Platform Technology
- Intel vPro Platform
- Localisation
- Processor
- Intel Core i7 (8th Gen) 8700 / 3.2 GHz (4.6 GHz) (6-core)
- Processor Socket
- LGA1151 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 12 MB
- Cache Per Processor
- 12 MB
- RAM
- 16 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-21333
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - SATA 6Gb/s - 2.5"
- Optical Storage
- DVD-Writer
- Card Reader
- 5 in 1
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Controller
- PCIe 3.0 x16 - NVIDIA GeForce GTX 1060 / Intel UHD Graphics 630
- Video Memory
- 3 GB GDDR5 SDRAM
- Audio Output
- Stereo
- Networking
- GigE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 15.4 cm x 37 cm x 36.5 cm
- 9.86 kg
- Limited warranty - parts and labour - 3 years - on-site
- Personal computer
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 2.0) Security Chip
- Localisation
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.6 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA1151 Socket
- Chipset Type
- Intel Q370
Cache Memory
- Installed Size
- 12 MB
- 12 MB
RAM
- Installed Size
- 16 GB / 64 GB (max)
- Technology
- Effective Memory Speed
- 2666 MHz
- Rated Memory Speed
- 2666 MHz
- Memory Specification Compliance
- PC4-21333
- Form Factor
- DIMM 288-pin
- Slots
- 4 (Total) / 3 (empty)
- Configuration Features
- 1 x 16 GB
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 512 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x SATA
- Controller Interface Type
- SATA 6Gb/s
Optical Storage
- DVD-Writer - SATA
Card Reader
- 5 in 1 card reader
- Supported Flash Memory Cards
- SD Memory Card, SDHC Memory Card, SDXC Memory Card
Monitor
- Monitor Type
- None.
Graphics Controller
- Interface Type
- PCIe 3.0 x16
- Graphics Processor
- Video Memory
- 3 GB GDDR5 SDRAM
- Video Interfaces
- DVI, HDMI, DisplayPort
- HDCP Compatible
Audio Output
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 192 kHz
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Keyboard Name
- HP Business Slim Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Controller
- Intel I219-LM
- Data Link Protocol
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
- Bays
- 2 (total) / 2 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" , 1 (total) / 1 (free) x external 5.25" x 1/2H
- Slots
- 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 2 (total) / 2 (free) x M.2 Card - 2230/2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 , 1 (total) / 1 (free) x PCIe 3.0 x16 (x4 mode) , 1 (total) / 0 (free) x PCIe 3.0 x16
- 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x USB 3.1 Gen 2 (1 in front) , 5 x DisplayPort , 1 x headphones (1 in front) , 1 x headphones/microphone (1 in front) , 1 x audio line-out (1 rear) , 1 x audio line-in (1 rear) , 1 x LAN (Gigabit Ethernet) , 1 x DVI-D , 1 x HDMI
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- CCC, RoHS, WEEE, CECP, SEPA
- Power supply
- Voltage Required
- Power Provided
- 500 Watt
- 80 PLUS Certification
- 80 PLUS Gold
- Efficiency
- 87% at 20% Load (115 VAC), 90% at 50% Load (115 VAC), 87% at 100% Load (115 VAC)
- Power Factor Correction
- Yes (active)
Operating System / Software
- OS Provided
- Windows 10 Pro 64-bit Edition English
- 15.4 cm
- 37 cm
- 36.5 cm
- 9.86 kg
- Shipping Width
- 29.9 cm
- Shipping Depth
- 47.8 cm
- Shipping Height
- 51.7 cm
- Shipping Weight
- 11.34 kg
- 10 °C
- 35 °C
- 10 - 90% (non-condensing)
Warranties (4)
HP 3 Year NBD On-Site Optional Customer Self Repair Desktop/Workstation Only Hardware Service | In Stock | £33.26 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 4 Years On-Site | In Stock | £65.71 |
HP Care Pack NBD Hardware Support with Disk Retention Extended Service Agreement 3 Years On-Site | In Stock | £45.13 |
HP Care Pack Next Business Day Hardware Support with Disk Retention 5 Years - On-Site | In Stock | £86.30 |
Monitors (2)
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
Keyboards and Mice (1)
HP Premium Wireless Mouse | In Stock | £38.00 |
Other bundles (4)
HPE DisplayPort To VGA Adapter | In Stock | £13.72 |
HPE DisplayPort DVI-D Adapter | In Stock | £13.23 |
HP Dual Head Keyed Cable Lock | In Stock | £43.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
