HP 800 G3 SFF Intel Core i5-7500 4GB 500GB Windows 10 Pro
Quicklinx: CP4NWS00 Mfr#: Z4D04ET#ABU
Processor Type: Core i5
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 500GB, 500GB
Storage Type: HDD
  • Core i5
Hurry, only 1 left in stock!
£693.87 ex VAT
£832.64 inc VAT
Experience amazing productivity plus superb reliability, security, manageability and big portfolio of solutions with the powerful HP EliteDesk 800 G2, expandable enterprise-class PC from HP.
Performance first
High-performance users will enjoy the powerful combination of 7th Gen Intel® Core™ processors, optional Intel® Optane™ memory and SSDs, and HP Velocity that improves data transfer rates over challenged networks to drive productivity in the workplace.
Expansion that extends your investment
The full value of your investment comes with configuration that extends the life of your PC. The HP EliteDesk 800 SFF has four bays and four slots, plus two additional M.2 connectors, and plenty of configurable ports.
Strong security, powerful manageability
Get powerful protection and simplified management from HP’s most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager
Configurable I/O Port for displays
Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort™, HDMI or USB Type-C™ alternate mode DisplayPort™.
  • Performance first
    High-performance users will enjoy the powerful combination of 7th Gen Intel Core processors, optional Intel Optane memory and SSDs, and HP Velocity that improves data transfer rates over challenged networks to drive productivity in the workplace.
  • Expansion that extends your investment
  • Strong security, powerful manageability
    Get powerful protection and simplified management from HP's most secure and manageable PCs. HP Sure Start Gen3 protects against BIOS attacks while the HP Manageability Integration Kit allows you to easily manage devices through Microsoft System Center Configuration Manager.
  • Configurable I/O Port for displays
    Configure a rear I/O port for customizable display connections with your choice of VGA, DisplayPort , HDMI or USB Type-C alternate mode DisplayPort .
HP EliteDesk 800 G3 - SFF - Core i5 7500 3.4 GHz - 4 GB - 500 GB - UK
Personal computer - small form factor
Platform Technology
Intel vPro Technology
1 x Intel Core i5 (7th Gen) 7500 / 3.4 GHz (3.8 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 64 GB (max) DDR4 SDRAM - non-ECC
Storage Controller
SATA
Hard Drive
1 x 500 GB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 630 Dynamic Video Memory Technology
Audio Output
Stereo
GigE
Keyboard
OS Provided
33.8 cm x 30.8 cm x 10 cm
5.31 kg
Pricing Type
Promo
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Platform Technology
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel Q270
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 64 GB (max)
Effective Memory Speed
2400 MHz
Rated Memory Speed
2400 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
DisplayPort
HDCP Compatible
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3az
Bays
2 (total) / 1 (free) x internal 3.5" , 1 (total) / 0 (free) x external 5.25" Slim Line , 1 internal 2.5"
Slots
1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 1 (free) x M.2 Card - 2230 (x1 mode) , 1 (total) / 1 (free) x M.2 Card - 2280 (x4 mode) , 2 (total) / 2 (free) x PCIe 3.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile
6 x USB 3.1 Gen 1 (2 front, 4 rear) , 1 x USB-C 3.1 Gen 1 (1 in front) (charging) , 1 x headphones/microphone (1 in front) , 2 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x audio line-out , 1 x audio line-in , 4 x USB 2.0 (2 front, 2 rear) (two of them with wake functionality, one of them is fast-charging) , 1 x VGA
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, CCC, Common Criteria EAL4+, CECP, SEPA, low halogen
Pricing Type
Promo
Power supply
Nominal Voltage
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Platinum
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager, Windows Defender, HP Velocity, HP Secure Erase, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP JumpStart, HP Noise Cancellation, HP Client Security Suite Gen3, HP Notifications, HP Manageability & Integration Kit
ENERGY STAR Certified
33.8 cm
30.8 cm
10 cm
5.31 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP 800 G3 SFF Intel Core i5-7500 4GB 500GB Windows 10 Pro Bundle deal on HP 800 G3 SFF Intel Core i5-7500 4GB 500GB Windows 10 Pro
£793.04
Storage Type: HDD
Processor Model: I5-7500
Type: Personal computer
Case Style: Desktop
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 500 - 750
