HP 78 Tri-colour Inkjet Print Cartridges deliver clear, vivid colour images. Patented, dye-based HP colour inks and print cartridge technology make professional-quality printing easy and reliable. Available in 2 sizes to suit different needs.
The HP 78 Tri-colour Inkjet Print Cartridges deliver clear, vivid colour images every time you print
Patented, dye-based colour HP ink formulations for clear, vivid images every time you print. -
Easy to use and maintain
Simple to install and easy to replace for low maintenance, trouble-free printing. -
HP reliability delivers value
The HP 78 was 50 times more reliable, on average, than the leading remanufactured brands tested.
- HP 78 - colour (cyan, magenta, yellow) - original - ink cartridge
- Product Type
- Ink cartridge
- Printing Technology
- Ink-jet
- Printing Colour
- Colour (cyan, magenta, yellow)
- Capacity
- 19 ml
- Yield
- Up to 560 pages at 15% coverage
- Localisation
- English / Europe
- Compatible with
- Deskjet 1180, 3810, 3816, 3820, 3822, 810, 812, 825, 840, 841, 842, 843, 845, 920, 940, 950; DeskWriter 310; Digital Copier 310; Fax 1230, 920, 950; Officejet 5110, 720, 7205, 7208, v30, v40, v45; psc 500, 720, 750, 760, 920, 950
- Shipping Weight
- 170 g
- Localisation
- English / Europe
Consumable
- Consumable Type
- Ink cartridge
- Ink-jet
- Included Qty
- 1-pack
- Capacity
- 19 ml
- Yield
- Compatible with
- HP Deskjet 1180C, 3810, 3816, 3820, 3820c, 3820v, 3820w, 3822, 810, 810c, 812c, 825c, 825cvr, 840, 840c, 841c, 842c, 843c, 843cxe, 845c, 845cvr, 920c, 920cvr, 920Cxi, 940c, 940cvr, 940cw, 940Cxi, 950, 950c , HP DeskWriter 310 , HP Digital Copier 310 , HP Fax 1230, 1230xi, 920, 950 , HP Officejet 5110, 5110v, 5110xi, 720, 7205, 7208, v30, v40, v40xi, v45 , HP psc 500, 500cxi, 500xi, 720, 750, 750xi, 760, 920, 950, 950vr, 950xi
