Designed for the modern workforce, this cost-effective ultrathin HP EliteBook 745 helps drive performance with impressive productivity features that allow you to stay connected and collaborate at your best.
Elevate performance. Enhance productivity.
Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs2 with up to Radeon™ R7 integrated graphics.
Incredibly thin and impressively featured
Stay portable without adapters with VGA, Display Port, Ethernet, USB, USB-C™, and enterprise docking capabilities, all on an 18.9mm ultrathin and light design.
Security and management made simple
HP Sure Start with Runtime Intrusion Detection protects the PC and helps ensure uninterrupted productivity by automatically detecting and recovering from BIOS corruption or attacks. Manage the fleet with HP Touchpoint Manager and DASH manageability.
Next-level collaboration
Calls and media are loud and clear letting you collaborate effectively with expertly tuned Audio by Bang & Olufsen, HP Audio Boost, HP Noise Cancellation, and premium speakers.
Elevate performance
Unleash the full potential of your applications with 6th generation or new high-performance 7th generation AMD PRO APUs with up to Radeon R7 integrated graphics. -
Stay portable without adapters with VGA, Display Port, Ethernet, USB, USB-C , and enterprise docking capabilities, all on an 18.9mm ultrathin and light design. -
HP Sure Start with Runtime Intrusion Detection protects the PC and helps ensure uninterrupted productivity by automatically detecting and recovering from BIOS corruption or attacks. Manage the fleet with HP Touchpoint Manager and DASH manageability. -
- HP EliteBook 745 G4 - 14" - A10 PRO-8730B - 4 GB RAM - 500 GB HDD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Processor
- AMD A10 PRO-8730B / 2.4 GHz (3.3 GHz) / 2 MB Cache
- Memory
- 4 GB DDR4 (1 x 4 GB)
- Storage
- 500 GB HDD / 7200 rpm
- Optical Drive
- No optical drive
- Display
- 14" LED backlight 1366 x 768 / HD
- Graphics
- AMD Radeon R5
- Input Device
- DualPoint
- Keyboard
- UK
- Keyboard Backlight
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
- Battery
- 3-cell
- Dockable
- Security
- Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
- 33.8 cm x 23.7 cm x 1.89 cm
- 1.48 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 3 years , Limited warranty - battery - 3 years
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- RAM
- 4 GB (1 x 4 GB)
- Max RAM Supported
- 16 GB
- Technology
- DDR4 SDRAM
- Speed
- 1866 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 500 GB HDD SATA 6Gb/s / 7200 rpm
Display
- 14" - TN
- LCD Backlight Technology
- LED backlight
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Brightness
- 220 cd/m²
- Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- AMD Radeon R5
- Camera
- Yes - 720p
- Sound
- Stereo speakers, two microphones
- Audio Features
- Bang & Olufsen Audio
Input
- Keyboard, touchpad, DualPoint
- Keyboard Layout
- UK
- Spill-resistant, gesture function
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
- Network Interface
- Gigabit Ethernet
- Ethernet Controller
- Broadcom BCM5762
- Miracast
- IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
- Technology
- 3-cell lithium polymer
- Capacity
- 51 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- Slots
- 1 x Micro-SIM card (1 free)
- USB 3.1 Gen 1 (charging) , USB 3.1 Gen 1 , USB-C , DisplayPort , LAN , Dock , Headphone/microphone combo jack
- Memory Card Reader
- Yes (SD Card, SDHC Card, SDXC Card)
Software
- Software Included
- Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, HP Systems Software Manager (free download), HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP JumpStart, HP JetAdvantage Connect, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3
- Case Material
- Aluminum, magnesium alloy
- Dockable
- Security
- HP DuraKeys, BIOS Absolute Persistence, HP SureStart, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication, Master Boot Record Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- ACPI, CSA, UL, VCCI, BSMI, SABS, SASO, CCC, FCC, ICES, KC, EAC, CIT, RCM
- Localization
- 1.48 kg
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine pulse
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine pulse
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
