Product
HP 728 40-ML Cyan DesignJet Ink Cartridge
Quicklinx: D2LMWS00 Mfr#: F9J63A
Type: Ink Cartridge
27 in stock
£30.54 ex VAT
£36.64 inc VAT
Facilitate communication and collaboration with quality prints from clear, easily readable drawings to colorful presentatins. To help reduce downtime and improve productivity-and protect your investment-Original HP inks are designed with your HP DesignJet printer or MFP as an optimized printing system. Choose from a range of cartridge sizes from 40 to 300 ml. Take advantage of free, convenient ink cartridge return and recycling.
  • Produce crisp, clear CAD, general-purpose prints
    Present your professional best with the accurate, clear prints produced by Original HP inks.Get dark blacks and vivid colors with four Original HP inks and the HP printhead.Avoid waste and rework-Original HP printing materials and inks work together to get the job done right.
  • Help reduce downtime and improve productivity
    See accurate, professional results, print after print, cartridge after cartridge with Original HP inks.Intelligence built into Original HP ink cartridges and printer continuously optimizes quality, reliability.Print fast, move fast-Original HP inks enable fast print speeds and produce smudge-resistant prints.To keep you printing smoothly, we put Original HP inks through rigorous manufacturing and testing processes.
  • A choice of cartridge sizes fit the way you work
    High-capacity 300-ml ink cartridges enable more unattended printing.You can also choose more affordable 40- or 130-ml HP DesignJet ink cartridges.No need to check-Original HP supplies and the printer interact to alert you when supplies need to be replaced.
HP 728 - dye-based cyan - original - DesignJet - ink cartridge
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Printing Colour
Dye-based cyan
40 ml
Compatible with
DesignJet T730, T830
Consumable
Consumable Type
Ink cartridge
Printing Technology
Ink-jet
HP Sub-brand
DesignJet
Dye-based cyan
Included Qty
1-pack
40 ml
Compatible with
HP DesignJet T730, T830
Type: Ink Cartridge
Brand: HP
Price Range Ex VAT: 0 - 50
