HP 705 G3 EliteDesk MT A Series A10-9700 8GB SSD 256GB
Quicklinx: CK97WS00 Mfr#: Y4U11EA#ABU
Processor Type: A10
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
Storage Type: SSD
  • AMD Radeon R7
£720.00 ex VAT
£864.00 inc VAT
The HP EliteDesk 705 delivers impressive value with uncompromising performance, security, and manageability. Customize your HP EliteDesk 705 with expandable options that provide an enterprise-class experience to meet virtually any business need.
Fit user needs and the budget
Power your PC with the latest 7th generation AMD Pro A-Series APUs and upgrade your system with up to 64 GB of DDR4 memory, the latest SSD drives, graphics, and HP accessories without breaking the budget.
Security built in
IT efficiency reigns supreme when it’s backed by comprehensive security solutions, including HP BIOSphere with HP Sure Start with Protection of BIOS Configuration, Policy and TPM 2.0
Reliability for the long haul
This work-ready PC is designed with platform stability up to 18 months for a long life cycle. Rest easy with a PC that passed 120,000 hours of testing and is designed to undergo MIL-STD 810G testing.
Pure performance and enhanced visual experience
The latest AMD PRO A-Series APUs with Radeon™ graphics deliver desktop performance optimized for diverse digital workloads and dependable daily productivity across your business.
HP EliteDesk 705 G3 - micro tower - A10 9700 3.5 GHz - 8 GB - 256 GB
Personal computer - micro tower
1 x AMD A10 9700 / 3.5 GHz (3.8 GHz) (Quad-Core)
Cache Memory
2 MB L2 Cache
Cache Per Processor
2 MB
RAM
8 GB (installed) / 64 GB (max) - DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 256 GB - SATA 6Gb/s
Optical Storage
DVD SuperMulti
Card Reader
5 in 1
Graphics Controller
AMD Radeon R7
Audio Output
Stereo
GigE
OS Provided
17 cm x 34 cm x 35.5 cm
6.76 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 3 years - on-site
Personal computer
Product Form Factor
Micro tower
Built-in Devices
Speaker, solenoid hood lock
Embedded Security
Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.8 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
AMD B350 FCH
Cache Memory
Installed Size
L2 Cache - 2 MB
Cache Per Processor
2 MB
RAM
Installed Size
8 GB / 64 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
SSD
1 x 256 GB
Interface Type
SATA 6Gb/s
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD SuperMulti - SATA
Card Reader
5 in 1 card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card, SDXC Memory Card, SDHC UHS-I Memory Card, SDHC UHS-II Memory Card
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
AMD Radeon R7
Video Interfaces
VGA, DisplayPort
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS Studio Sound
Ethernet Controller
Broadcom BCM5762
Remote Management Protocol
ASF 2.0
Wake on LAN (WoL), PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1as, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 2 (total) / 1 (free) x internal 3.5"
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - full-height (x4 mode) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-height
6 x USB 2.0 (2 front, 4 rear) , 4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 1 x headphones (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet)
Carrier cage
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), chassis intrusion sensor
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+, low halogen
TAA Compliant
Power supply
Nominal Voltage
Power Provided
280 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
93%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Pro 64-bit Edition English
Software
Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Systems Software Manager, Windows Defender, HP BIOSphere, CyberLink Power Media Player, HP Client Catalog, HP Driver Packs, HP BIOS Config Utility, HP CIK for Microsoft SCCM, HP Image Assistant, HP JumpStart
ENERGY STAR Certified
17 cm
34 cm
35.5 cm
6.76 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP 705 G3 EliteDesk MT A Series A10-9700 8GB SSD 256GB Bundle deal on HP 705 G3 EliteDesk MT A Series A10-9700 8GB SSD 256GB
£905.22
saving £8.33
£819.17
Processor Type: A10
Storage Type: SSD
Processor Model: A10-9700
Type: Personal computer
Case Style: Micro tower
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Brand: HP
Price Range Ex VAT: 500 - 750
