Power and charge your notebook or tablet from its USB-C port with the HP 65W USB-C Power Adapter.
Simple to use
Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet. -
Easy to carry and store
Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it. -
World-class support
Rest easy with a one-year limited warranty.
- HP - power adapter - 65 Watt
- Power adapter - external
- 220 g
- Localisation
- English / United Kingdom
- Input Voltage
- AC
- Output Voltage
- 5 / 9 / 10 / 12 / 15 / 20 V
- Power Capacity
- 65 Watt
- Input Connectors
- 24 pin USB-C
- 7.4 cm x 7.4 cm x 2.85 cm
- 1-year warranty
- Designed For
- Pro x360; ProBook 430 G5, 430 G6, 430 G7, 430 G8, 440 G5, 445r G6, 44X G6, 44X G7, 44X G8, 44X G9, 455r G6, 45X G5, 45X G6, 45X G7, 45X G8, 45X G9, 630 G8, 635, 640 G5, 640 G8, 650 G5, 650 G8, Fortis 14 G9; ProBook x360; ZBook 14u G6, 15u G6; ZBook Firefly 14 G7, 14 G8, 14 G9, 15 G7, 16 G9
- Localisation
- Input Voltage
- AC
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- 24 pin USB-C
- Output Voltage
- Max Electric Current
- 8 A
- Power Capacity
- 65 Watt
- Efficiency
- 81.5% min at AC 115/230 V (5V/3A), 86.7% min at AC 115/230 V (9V/3A), 88% min at AC 115/230 V (10V/5A), 88% min at AC 115/230 V (12V/5A), 89% min at AC 115/230 V (15V/4.33A), 89% min at AC 115/230 V (20V/3.25A)
- MTBF
- 100,000 hours
- FCC Class B certified, EN 60950, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, cULus, LVD, NOM-1-NYCE
- Limited warranty - 1 year
- 0 °C
- 35 °C
- 5 - 95%
- 7.4 cm
- 7.4 cm
- 2.85 cm
- 220 g
- Designed For
- HP Elite Dragonfly Notebook , HP Elite x360 1040 G9 Notebook, 830 G9 Notebook , HP EliteBook 1040 G4 Notebook, 1040 G9 Notebook, 640 G9 Notebook, 645 G9 Notebook, 650 G9 Notebook, 655 G9 Notebook, 735 G5 Notebook, 735 G6 Notebook, 745 G5 Notebook, 745 G6 Notebook, 755 G5 Notebook, 830 G6 Notebook, 830 G7 Notebook, 830 G8 Notebook, 830 G9 Notebook, 835 G7 Notebook, 835 G8 Notebook, 835 G9 Notebook, 840 Aero G8 Notebook, 840 G6 Notebook, 840 G8 Notebook, 840 G9 Notebook, 845 G7 Notebook, 845 G8 Notebook, 845 G9 Notebook, 850 G6 Notebook, 850 G7 Notebook, 850 G8 Notebook, 855 G7 Notebook, 855 G8 Notebook, 860 G9 Notebook, 865 G9 Notebook , HP EliteBook x360 1012 G2 Notebook, 1020 G2 Notebook, 1030 G2 Notebook, 1030 G3 Notebook, 1030 G4 Notebook, 1030 G7 Notebook, 1030 G8 Notebook, 1040 G5 Notebook, 1040 G6 Notebook, 1040 G7 Notebook, 1040 G8 Notebook, 830 G5 Notebook, 830 G6 Notebook, 830 G8 Notebook , HP Pro x360 435 G9 Notebook, Fortis 11 G10 Notebook, Fortis 11 G9 Notebook , HP ProBook 430 G5 Notebook, 430 G6 Notebook, 430 G7 Notebook, 430 G8 Notebook, 440 G5 Notebook, 440 G6 Notebook, 440 G7 Education Edition Notebook, 440 G7 Notebook, 440 G8 Notebook, 440 G9 Notebook, 445 G6 Notebook, 445 G7 Notebook, 445 G8 Notebook, 445 G9 Notebook, 445r G6 Notebook, 450 G5 Notebook, 450 G6 Notebook, 450 G7 Notebook, 450 G8 Notebook, 450 G9 Notebook, 455 G5 Notebook, 455 G6 Notebook, 455 G7 Notebook, 455 G8 Notebook, 455 G9 Notebook, 455r G6 Notebook, 630 G8 Notebook, 635 Aero G7 Notebook, 640 G5 Notebook, 640 G8 Notebook, 650 G5 Notebook, 650 G8 Notebook, Fortis 14 G9 Notebook , HP ProBook x360 11 G5 Education Edition Notebook, 11 G6 Education Edition Notebook, 11 G7 Education Edition Notebook, 440 G1 Notebook , HP ZBook 14u G6 Mobile Workstation, 15u G6 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 14 G8 Mobile Workstation, 14 G9 Mobile Workstation, 15 G7 Mobile Workstation, 16 G9 Mobile Workstation
