HP 65W USB-C G2 Power Adapter
Quicklinx: F6ZGWS00 Mfr#: 1HE08AA#ABU
More than 50 in stock
£39.19 ex VAT
£47.02 inc VAT
Power and charge your notebook or tablet from its USB-C port with the HP 65W USB-C Power Adapter.
  • Simple to use
    Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
  • Easy to carry and store
    Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
  • World-class support
    Rest easy with a one-year limited warranty.
HP - power adapter - 65 Watt
Power adapter - external
220 g
English / United Kingdom
Input Voltage
AC
Output Voltage
5 / 9 / 10 / 12 / 15 / 20 V
Power Capacity
65 Watt
Input Connectors
24 pin USB-C
7.4 cm x 7.4 cm x 2.85 cm
1-year warranty
Chromebook 11 G9, 11MK G9, 14, 14 G7; Chromebook x360; Elite x2; EliteBook 83X G8, 840, 84X G8, 85X G8; EliteBook x360; ENVY 13, 17; ENVY x360; Pavilion x360; Pro c640 G2, c645; ProBook 430 G8, 44X G8, 45X G8, 630 G8, 635, 650 G8; ProBook x360; Spectre Folio 13; Spectre x360; ZBook Firefly 14 G8
Input Voltage
AC
Frequency Required
47 - 63 Hz
Input Connectors
24 pin USB-C
Output Voltage
Max Electric Current
8 A
Power Capacity
65 Watt
Efficiency
81.5% min at AC 115/230 V (5V/3A), 86.7% min at AC 115/230 V (9V/3A), 88% min at AC 115/230 V (10V/5A), 88% min at AC 115/230 V (12V/5A), 89% min at AC 115/230 V (15V/4.33A), 89% min at AC 115/230 V (20V/3.25A)
MTBF
100,000 hours
FCC Class B certified, EN 60950, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, cULus, LVD, NOM-1-NYCE
Limited warranty - 1 year
35 °C
5 - 95%
7.4 cm
7.4 cm
2.85 cm
220 g
HP Chromebook 11 G9, 14 G7, 14b-na0432ng , HP Chromebook x360 11 G4, 14c-ca0065nr, 14c-ca0085nr, 14c-ca0235ng, 14c-ca0350ng, 14c-ca0510na, 14c-cc0001nd, 14c-cc0002nf, 14c-cc0013no, 14c-cc0700nz, 14c-cc0735nd , HP Elite x2 G8 , HP EliteBook 835 G8, 840 Aero G8, 845 G8, 855 G8 , HP ENVY 13-ba0080tu, 13-ba1000nn, 13-ba1009nn, 13-ba1010nr, 13-ba1014na, 13-ba1019ns, 13-ba1022nn, 13-ba1029nn, 13-ba1071cl, 13-ba1075nr, 13-ba1076nr, 13-ba1085cl, 13-ba1097nr, 13-ba1154ng, 17-ce2010nr, 17-ce2055cl, 17-cg0019nr, 17-cg0033nf, 17-cg0155ng, 17-cg0177ng, 17-cg1000na, 17-cg1001na, 17-cg1009nn, 17-cg1011nn, 17-cg1013nn, 17-cg1016nn, 17-cg1017nn, 17-cg1173ng, 17-cg1177ng, 17-cg1300ng, 17-cg1782ng, 17-ch0012nb, 17-ch0250nd , HP ENVY x360 13-ay0006ca, 13-ay0024no, 13-ay0035no, 13-ay0136ng, 13-ay0178ng, 13-ay0360ng, 13-ay0505sa, 15-ds1010nr, 15-ds1010wm, 15-ds1083cl, 15-ed0000nc, 15-ed0003ca, 15-ed0151ng, 15-ed0503na, 15-ed1000no, 15-ed1001na, 15-ed1002nn, 15-ed1004nn, 15-ed1011nn, 15-ed1019nn, 15-ed1021nn, 15-ed1024nn, 15-ed1152ng, 15-ed1155ng, 15-ed1176ng, 15-ed1178ng, 15m-ed1013dx, 15m-ed1023dx , HP Pavilion x360 14-dw0007nf, 14-dw0158ng, 14-dw0522na, 14-dw1003nf, 14-dw1004nl, 14-dw1006nf, 14-dw1007nl, 14-dw1011na, 14-dw1011nl, 14-dw1013nl, 14-dw1016na, 14-dw1019ns, 14-dw1020ns, 14-dw1021na, 14-dw1021ns, 14-dw1025na, 14-dw1027na, 14-dw1098nr, 14-dw1176ng, 14-dw1210ng, 14-dw1657ng , HP Pro c640 G2 Chromebook, c640 G2 Chromebook Enterprise , HP Spectre Folio 13-ak0017nr , HP Spectre x360 13-aw0003ns, 13-aw0105tu, 13-aw0501na, 13-aw2001nn, 13-aw2003dx, 13-aw2003nu, 13-aw2004nu, 13-aw2010ca, 13-aw2011nn, 13-aw2020nn, 13-aw2024na, 13-aw2024nn, 13-aw2034nn, 13-aw2036nn, 13-aw2047nn, 13-aw2048nn, 13-aw2053nn, 13-aw2355ng, 13-aw2701nz, 14-ea0003nl, 14-ea0007nn, 14-ea0009na, 14-ea0009nn, 14-ea0010nn, 14-ea0011nn, 14-ea0016nn, 14-ea0017nn, 14-ea0021nn, 14-ea0028nn, 14-ea0029nn, 14-ea0038nn, 14-ea0039no, 14-ea0902nz, 14-ea0912nz, 14-ea0922nz
Brand: HP
Stock Status: In stock
