Brand
HP 65W USB-C G2 Power Adapter
Quicklinx: F6ZGWS00 Mfr#: 1HE08AA#ABU
£38.59 ex VAT
£46.30 inc VAT
Power and charge your notebook or tablet from its USB-C port with the HP 65W USB-C Power Adapter.
  • Simple to use
    Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
  • Easy to carry and store
    Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
  • World-class support
    Rest easy with a one-year limited warranty.
HP - power adapter - 65 Watt
Power adapter - external
220 g
English / United Kingdom
Input Voltage
AC
Output Voltage
5 / 9 / 10 / 12 / 15 / 20 V
Power Capacity
65 Watt
Input Connectors
24 pin USB-C
7.4 cm x 7.4 cm x 2.85 cm
1-year warranty
Chromebook 11MK G9, 14, 14 G7; Chromebook x360; Elite x2; EliteBook 83X G8, 840, 84X G8, 85X G8; EliteBook x360; ENVY 13, 17; ENVY x360; Pavilion x360; Pro c640 G2, c645; ProBook 430 G8, 44X G7, 44X G8, 45X G8, 630 G8, 635, 650 G8; ProBook x360; Spectre Folio 13; Spectre x360; ZBook Firefly 14 G8
Input Voltage
AC
Frequency Required
47 - 63 Hz
Input Connectors
24 pin USB-C
Output Voltage
Max Electric Current
8 A
Power Capacity
65 Watt
Efficiency
81.5% min at AC 115/230 V (5V/3A), 86.7% min at AC 115/230 V (9V/3A), 88% min at AC 115/230 V (10V/5A), 88% min at AC 115/230 V (12V/5A), 89% min at AC 115/230 V (15V/4.33A), 89% min at AC 115/230 V (20V/3.25A)
MTBF
100,000 hours
FCC Class B certified, EN 60950, NORDIC, IEC 60950, UL 60950, EN55022 Class B, CCC, EMC, cULus, LVD, NOM-1-NYCE
Limited warranty - 1 year
35 °C
5 - 95%
7.4 cm
7.4 cm
2.85 cm
220 g
HP Chromebook 11MK G9 Education Edition, 14b-na0000AU, 14b-na0002AU, 14b-na0005na, 14b-na0006nl, 14b-na0007nl, 14b-na0010nr, 14b-na0010wm, 14b-na0011nl, 14b-na0016nl, 14b-na0017ns, 14b-na0035cl, 14b-na0091nr, 14b-na0350ng, 14b-na0435ng , HP Chromebook x360 11 G4 Education Edition, 11MK G3 Education Edition, 14c-ca0012nf, 14c-cc0014nf, 14c-cc0047nr, 14c-cc0060ng, 14c-cc0075ng, 14c-cc0435ng, 14c-cc0455ng , HP ENVY 13-ba0008na, 13-ba1000no, 13-ba1001ca, 13-ba1010ca, 13-ba1015nn, 13-ba1020ca, 13-ba1025od, 13-ba1026nn, 13-ba1030ca, 13-ba1040ca, 13-ba1047wm, 13-ba1050ca, 13-ba1053cl, 13-ba1060ca, 13-ba1063cl, 13-ba1072no, 13-ba1088ca, 13-ba1093cl, 13-ba1095cl, 13-ba1125od, 13-ba1178ng, 13-ba1756ng, 13-ba1775ng, 13-ba1858nd, 13-ba1859nd, 17-cg1000nl, 17-cg1010nr, 17-cg1026nn, 17-cg1029nr, 17-cg1045cl, 17-cg1055cl, 17-cg1065cl, 17-cg1075cl, 17-cg1171ng, 17-cg1175ng, 17-cg1359ng, 17-cg1775ng, 17-cg1xxx, 17-ch0000no, 17-ch0001no, 17-ch0002no, 17-ch0007nb, 17-ch0008nb, 17-ch0010nb, 17-ch0011nr, 17-ch0012nb, 17-ch0176ng, 17-ch0180ng, 17-ch0356ng, 17-ch0359ng, 17-ch0455ng, 17-ch0478ng, 17-ch1003nq, 17-ch1007nm, 17-ch1008nb, 17-ch1220nd, 17-ch1250nd, 17-ch1720nd, 17m-ch0013dx , HP ENVY x360 13-ay0006nk, 13-ay0012nk, 13-ay0013na, 13-ay0018na, 13-ay0025na, 13-ay0040AU, 13-ay0754ng, 13-ay0779ng, 15-dr1012TU, 15-dr1900ny, 15-ds1063cl, 15-ed0001ny, 15-ed0015na, 15-ed1004nb, 15-ed1019nb, 15-ed1027nb , HP Pavilion x360 14-dw0006nj, 14-dw0008nm, 14-dw1001nf, 14-dw1010nr, 14-dw1018nl, 14-dw1035na, 14-dw1051cl, 14-dw1500na , HP ProBook 440 G7 Education Edition , HP ProBook x360 11 G5 Education Edition, 11 G6 Education Edition, 11 G7 Education Edition , HP Spectre x360 13-aw1002nr, 13-aw2000nh, 13-aw2001nh, 13-aw2001nk, 13-aw2002nh, 13-aw2003nh, 13-aw2004nh, 13-aw2004nr, 13-aw2005nh, 13-aw2006nh, 13-aw2007nh, 13-aw2008nb, 13-aw2008nh, 13-aw2009nb, 13-aw2009nh, 13-aw2010nh, 13-aw2011nb, 13-aw2011nh, 13-aw2012nb, 13-aw2026na, 13-aw2994nb
Brand: HP
