HP 65W Smart AC Adapter
Quicklinx: C872WS00 Mfr#: H6Y89AA#ABU
More than 50 in stock
£11.76 ex VAT
£14.11 inc VAT
Feed your notebook with controlled servings of electricity. HP's new 65W Smart AC Adapter regulates power and offsets electrical spikes, is designed to reduce cable stress, and includes a special dongle to support current and prior HP models – perfect for replacing your notebook's power adapter or as a needed back-up.
  • Easy to use
    Control the flow while maintaining optimal performance utilizing smart-pin technology, drawing only minimal power when not in use, and helping provide reliable surge protection.
  • Power up wherever you work
    Protect your cable and improve cable manageability. The new right-angled (90°) 4.5mm connector allows access in tight spaces and takes stress off the cord by reducing bending.
  • World-class support
    Eliminate multiple adapters - a special dongle is provided that allows simple conversion from a 4.5mm connector to the 7.4mm used on some previous HP notebooks.
HP Smart AC Adapter - power adapter - 65 Watt
Power adapter - external
280 g
English / United Kingdom
Output Voltage
18.5 V
Power Capacity
65 Watt
Output connectors
1 x power DC jack 4.5 mm
4.5mm to 7.4mm power DC dongle
10.6 cm x 4.7 cm x 2.8 cm
HP 245 G7, 245 G8, 340 G7, 340S G7, 34X G5, 470 G7, 470 G8; Chromebox Enterprise G3; EliteBook 735 G6, 745 G6, 83X G8, 84X G8, 85X G8; EliteBook x360; Mobile Thin Client mt32, mt45, mt46; ProBook 430 G7, 440 G7, 445 G8, 450 G7, 455 G8, 455r G6, 635, 640 G5; ProBook x360; ZBook Firefly 14 G8, 15 G8
Input Voltage Range
AC 90 - 265 V
Frequency Required
47 - 63 Hz
Output Voltage
18.5 V
Power Capacity
65 Watt
Power cable , Power connector adaptor
Over voltage protection
CSA, UL, C-Tick, BSMI, GOST, cUL, GS, NOM, SABS, CCC, EMC, PSB, SII, PSE Mark, S Mark, KC, ISC
5 °C
35 °C
10.6 cm
4.7 cm
2.8 cm
280 g
Shipping Weight
0.6 kg
HP 215 G1, 240 G1, 240 G2, 245 G1, 245 G2, 245 G7, 245 G8, 248 G1, 250 G1, 250 G2, 250 G3, 250 G5, 255 G1, 255 G2, 255 G5, 3005pr USB 3.0 Port Replicator, 340 G1, 340 G2, 340 G5, 340 G7, 340S G7, 348 G5, 450, 455, 470 G7, 470 G8, 631, 636 , HP Chromebook 11 G5, 13 G1, 14, 14 G4 , HP Chromebox Enterprise G3 , HP Elite x2 1011 G1 , HP EliteBook 1030 G1, 1040 G3, 2170p, 2570p, 2760p, 725 G2, 725 G3, 725 G4, 735 G5, 735 G6, 745 G2, 745 G3, 745 G4, 745 G5, 745 G6, 755 G2, 755 G3, 755 G4, 755 G5, 820 G1, 820 G2, 820 G3, 820 G4, 830 G5, 830 G6, 830 G8, 835 G8, 840 G1, 840 G2, 840 G3, 840 G4, 840 G5, 840 G6, 840 G8, 840r G4, 845 G8, 8470p, 8470w, 850 G1, 850 G2, 850 G3, 850 G4, 850 G5, 850 G6, 850 G8, 855 G8, 8570p, 8730p , HP EliteBook Folio 1020 G1, 1040 G1, 1040 G2, 9470m , HP EliteBook Revolve 810 G1 Tablet, 810 G2 Tablet, 810 G3 Tablet , HP EliteBook x360 1030 G2, 830 G6, 830 G8 , HP Mobile Thin Client mt32, mt40, mt41, mt45, mt46 , HP Pro x2 612 G1 , HP ProBook 11 G1 (Education Edition), 430 G1, 430 G2, 430 G3, 430 G4, 430 G5, 430 G7, 440 G3, 440 G4, 440 G5, 440 G7, 445 G8, 445r G6, 450 G0, 450 G1, 450 G2, 450 G3, 450 G4, 450 G5, 450 G7, 4545s, 455 G1, 455 G3, 455 G4, 455 G5, 455 G8, 455r G6, 470 G0, 470 G1, 470 G2, 470 G3, 470 G4, 470 G5, 635 Aero G8, 640 G1, 640 G2, 640 G3, 640 G4, 640 G5, 645 G1, 645 G2, 645 G3, 645 G4, 6470b, 6475b, 650 G1, 650 G2, 650 G3, 650 G5, 655 G1, 655 G2, 655 G3, 6570b , HP ProBook x360 11 G5, 11 G7, 435 G8, 440 G1 , HP Spectre 13 Pro , HP Spectre Pro x360 G1, x360 G2 , HP Spectre x2 Pro 13 , HP Stream Pro 11 G3, 11 G4 (Education Edition) , HP ZBook 14 G2 Mobile Workstation, 14 Mobile Workstation, 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15u G2 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G6 Mobile Workstation , HP ZBook Firefly 14 G8 Mobile Workstation, 15 G8 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Brand: HP
Stock Status: In stock
