HP 65W Slim with USB Adapter (interchangeable tips)
Quicklinx: 9RC8WS00 Mfr#: H6Y82AA#ABU
Device Type: Laptop
More than 50 in stock
£60.20 ex VAT
£72.24 inc VAT
Standard delivery Delivered within 3-5 working days
Be productive with the HP Slim 65W Combo Adapter, which can power your HP Business Notebook or Ultrabook .
HP Slim - power adapter - 65 Watt
Power adapter - external
English / United Kingdom
Power Capacity
65 Watt
1-year warranty
HP 24X G7, 24X G8, 25X G8, 340 G7, 340S G7, 34X G5, 470 G7, 470 G8; EliteBook 735 G6, 830 G8, 83X G7, 840 G8, 845 G7, 850 G8, 85X G7; EliteBook x360; ENVY Pro; Mobile Thin Client mt22, mt32; ProBook 430 G7, 430 G8, 440 G7, 44X G8, 450 G7, 45X G8, 630 G8, 635; ProBook x360; ZBook Firefly 14 G7, 15 G7
Power Capacity
65 Watt
Limited warranty - 1 year
HP 240 G8, 245 G4, 245 G5, 245 G7, 245 G8, 246 G7, 250 G5, 250 G7, 250 G8, 255 G5, 255 G7, 255 G8, 340 G5, 340 G7, 340S G7, 348 G5, 470 G7, 470 G8 , HP Chromebook 14 G4, 14-ak000nb, 14-ak000nf, 14-ak000nz, 14-ak001nf, 14-ak001tu, 14-ak002tu, 14-ak003na, 14-ak003tu, 14-ak004na, 14-ak004nf, 14-ak004no, 14-ak004tu, 14-ak005na, 14-ak005nf, 14-ak005no, 14-ak006na, 14-ak010nr, 14-ak013dx, 14-ak020nr, 14-ak030nr, 14-ak031nr, 14-ak040nr, 14-ak040wm, 14-ak041dx, 14-ak050nr, 14-ak060nr, 14-ca061dx, 14-x023ds , HP Chromebook x360 11 G1 , HP EliteBook 1030 G1, 1040 G3, 725 G3, 735 G5, 735 G6, 820 G3, 820 G4, 830 G5, 830 G6, 830 G7, 830 G8, 835 G7, 840 G3, 840 G4, 840 G5, 840 G6, 840 G8, 840r G4, 845 G7, 850 G3, 850 G4, 850 G5, 850 G6, 850 G7, 850 G8, 855 G7 , HP EliteBook x360 1030 G2, 830 G5, 830 G6, 830 G8 , HP ENVY Pro , HP Mobile Thin Client mt22, mt32 , HP Pavilion Chromebook 14-c001tu , HP ProBook 430 G3, 430 G5, 430 G6, 430 G7, 430 G8, 440 G3, 440 G5, 440 G6, 440 G7, 440 G8, 445 G8, 450 G3, 450 G5, 450 G6, 450 G7, 450 G8, 455 G3, 455 G5, 455 G8, 470 G3, 470 G5, 630 G8, 635 Aero G8, 640 G2, 640 G3, 640 G4, 640 G5, 645 G2, 645 G3, 645 G4, 650 G2, 650 G3, 650 G4, 650 G5, 655 G2, 655 G3 , HP ProBook x360 11 G1, 11 G2, 11 G3, 11 G4, 11 G5, 11 G6, 11 G7, 435 G8, 440 G1 , HP Spectre Pro x360 G2 , HP Spectre x2 12-a001na, 12-A001NG, 12-a004na, 12-a005na, 12-a010nd , HP Spectre x360 13-4020nd, 13-4020np, 13-4021ca, 13-4021ng, 13-4096nf, 13-4100nb, 13-4101la, 13-4101ng, 13-4102ng, 13-4102TU, 13-4103ng, 13-4103TU, 13-4104ng, 13-4105ng, 13-4111TU, 13-4190nd , HP Stream Pro 11 G3, 11 G4 (Education Edition) , HP x360 310 G2 , HP ZBook 14u G4 Mobile Workstation, 14u G5 Mobile Workstation, 14u G6 Mobile Workstation, 15u G3 Mobile Workstation, 15u G4 Mobile Workstation, 15u G5 Mobile Workstation, 15u G6 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 15 G7 Mobile Workstation , HP ZBook x2 G4 Detachable Workstation
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: 9RC8 044403
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £20.82
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: Laptop
Brand: HP
Stock Status: In stock
Stock Status: Used Stock
