AC power adapters from HP power your notebook and charge the internal battery simultaneously. These adapters provide you with the ability to power your notebook when away from the office or on the road. X3 Full compatibility depends on platform configuration. If 90W or higher is required note that the notebook will be powered when using basic applications and/or for charging. Performance delays may occur on specific platform configurations if lower than original power supply is used.
- HP - power adapter - 65 Watt
- Power adapter - external
- 220 g
- Output Voltage
- 5 / 19.5 V
- Power Capacity
- 65 Watt
- 12 cm x 5.8 cm x 1.7 cm
- Designed For
- Compaq CQ58; Presario CQ57, CQ58; HP 43X; EliteBook 27XX; EliteBook Folio 9470; EliteBook Revolve 810 G1; ENVY Pro; Folio 13; Folio 13; Pavilion Laptop dv6, dv7; Pavilion Sleekbook 14, 15; ProBook 430 G1, 450 G0, 45X G1, 45XX, 470 G0, 470 G1, 64X G1, 65X G1; Spectre XT Pro; SPECTRE XT TouchSmart 15
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 47 - 63 Hz
- Output Voltage
- 5 / 19.5 V
- Power Capacity
- 65 Watt
- Over voltage protection, built-in USB charger
- FCC Class B certified, CISPR 22 Class B, cUL, EN 60950, IEC950, NOM, UL 1950, EN55022 Class B
- 0 °C
- 40 °C
- 20 - 80%
- 12 cm
- 5.8 cm
- 1.7 cm
- 220 g
- Shipping Width
- 20 cm
- Shipping Depth
- 17.5 cm
- Shipping Height
- 6 cm
- Designed For
- Compaq CQ58-200SG, CQ58-200SO, CQ58-201SG, CQ58-202SD, CQ58-202SS, CQ58-202TU, CQ58-203SD, CQ58-206SD, CQ58-206SL, CQ58-210SW, CQ58-215EW, CQ58-216SL, CQ58-217SL, CQ58-218SL, CQ58-219SL, CQ58-221SL, CQ58-222SL, CQ58-225EL, CQ58-225SL, CQ58-230SF, CQ58-237SF, CQ58-250EC, CQ58-250SC, CQ58-250SG, CQ58-251SH, CQ58-252SA, CQ58-252SS, CQ58-253SS, CQ58-260EA, CQ58-261EA, CQ58-270SO, CQ58-271SD, CQ58-276SD, CQ58-282SG, CQ58-295EG, CQ58-300SA, CQ58-300SB, CQ58-300SW, CQ58-301SL, CQ58-301SS, CQ58-301SW, CQ58-302SA, CQ58-302SP, CQ58-303SD, CQ58-303SO, CQ58-304SA, CQ58-305EW, CQ58-305SA, CQ58-306SD, CQ58-307SL, CQ58-311SL, CQ58-313ES, CQ58-313SS, CQ58-319EW, CQ58-320EW, CQ58-325SR, CQ58-330SF, CQ58-347SG, CQ58-350SG, CQ58-351EO, CQ58-351SC, CQ58-351SO, CQ58-353SO, CQ58-373SD, CQ58-392SG, CQ58-bf9WM, CQ58-d01SA, CQ58-d28SA, CQ58-d36SF, CQ58-d50SO, CQ58-d56SR , Compaq Presario CQ56-109WM, CQ57-386NR, CQ57-420SW, CQ57-430SW, CQ57-431SC, CQ57-441SL, CQ58-100SF, CQ58-100SH, CQ58-124SZ, CQ58-135SW, CQ58-145SW, CQ58-150SI, CQ58-150SL, CQ62-219WM , HP 2140 Mini-Note, 3105m, 425, 430, 435, 610, 615, 625, 635 , HP EliteBook 2540p, 2560p, 2730p, 2760p, 8440p, 8460p, 8560p , HP EliteBook Folio 9470m , HP EliteBook Revolve 810 G1 Tablet , HP ENVY Pro , HP Folio 13-1000ea, 13-1000eo, 13-1008tu, 13-1010ef, 13-1016tu, 13-1051nr , HP Folio 13 , HP Mini 5101, 5102, 5103 , HP Mobile Thin Client 4410t , HP Pavilion Laptop dv6-3019wm, dv7-4069wm , HP Pavilion Sleekbook 14-b002eo, 14-b023au, 14-b031tu, 15-b004eo, 15-b006eo , HP ProBook 430 G1 Notebook, 4310s, 4320s, 4330s, 4420s, 4425s, 450 G0 Notebook, 450 G1 Notebook, 4510s, 4515s, 4520s, 4530s, 4540s, 455 G1 Notebook, 470 G0 Notebook, 470 G1 Notebook, 5310m, 5320m, 5330m, 6360b, 640 G1 Notebook, 6440b, 645 G1 Notebook, 650 G1 Notebook, 6540b, 655 G1 Notebook , HP Spectre XT Pro , HP SPECTRE XT TouchSmart 15-4000ew, 15-4095ca, 15-4101ef, 15-4110eo , HP Compaq 2230s, 6530b, 6730b, 6730s, 6735s
