HP 650 G3 Intel Core i5 7200U 15.6" 4GB 500GB Windows 10 Pro
Quicklinx: CN37WS00 Mfr#: Z2W53ET#ABU
Display Size: 15.6in
Processor Model: I5-7200U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 4GB, 4GB
Hard Drive Capacity: 500GB
  • Core i5
  • IEEE 802.11n
£764.29 ex VAT
£917.14 inc VAT
Get the most from your investment with configurations that support today's technology and legacy devices. The HP ProBook 650 is equipped with the newest security and productivity features and is compatible with your existing IT investments.
Blend new features with proven technology
Simplify deployment of new PCs. The HP ProBook 650 easily integrates into your current IT structure. Optional optical drives and legacy ports like a serial port, standard VGA port, and RJ-45 connection help reduce the costs of upgrading your PCs.
Mobilize your workforce
Give your deskbound workforce the benefits of mobility without sacrificing performance or breaking the budget with 7th Gen Intel® Core™ i3/i5/i7 processors, expansive DDR4 memory, and peripherals like the HP UltraSlim dock.
HP exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen3 and self-encrypting. Simplify management with HP configuration across the globe, available in more than 180 countries where HP conducts business.
Collaborate on the go
Business doesn’t stop when you are away from the office. HP Noise Cancellation Software, HP Audio Boost, Skype for business, and a 720p webcam are collaboration tools that help you communicate clearly with colleagues.
  • Blend new features with proven technology
  • Mobilize your workforce
    Give your deskbound workforce the benefits of mobility without sacrificing performance or breaking the budget with 7th Gen Intel Core i3/i5/i7 processors, expansive DDR4 memory, and peripherals like the HP UltraSlim dock.
  • HP exclusive security and manageability
  • Collaborate on the go
    Business doesn't stop when you are away from the office. HP Noise Cancellation Software, HP Audio Boost, Skype for business, and a 720p webcam are collaboration tools that help you communicate clearly with colleagues.
HP ProBook 650 G3 - 15.6" - Core i5 7200U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) 7200U / 2.5 GHz (3.1 GHz) / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD SuperMulti
Display
15.6" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Input Device
Pointing stick
Keyboard
Numeric Keypad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
37.8 cm x 25.7 cm x 2.74 cm
2.31 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-19200
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM
Display
15.6"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Brightness
220 cd/m²
45% colour gamut, Slim Design, HD standard-viewing angle (SVA) eDP anti-glare
Keyboard Name
HP Premium
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad, pointing stick
Keyboard Layout
Numeric Keypad
Volume control, spill-resistant, gesture function
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Miracast
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Slots
1 x SIM card (1 free)
USB-C , USB 3.0 , USB 3.0 (charging) , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
CyberLink Power2Go, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Workwise, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3
Dockable
Security
HP 3D DriveGuard, Automatic DriveLock, HP DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS, WEEE, Common Criteria EAL4+
Localization
2.31 kg
ENERGY STAR Certified
Software applications
HP 650 G3 Intel Core i5 7200U 15.6 Bundle deal on HP 650 G3 Intel Core i5 7200U 15.6" 4GB 500GB Windows 10 Pro
£946.46
saving £8.33
£863.46
Optical Storage: DVD±RW (±R DL) / DVD-RAM
Graphics: Intel HD Graphics 620
Hard Drive Type: HDD
Type: Laptop
Brand: HP
Price Range Ex VAT: 750 - 1000
