HP 650 G2 Intel Core i3-6100U 4GB 500GB  15.6" Windows 10 Pro
Quicklinx: C9PCWS00 Mfr#: Y3B16ET#ABU
  • Core i3
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
  • DVD-ROM
Equip your workforce with HP's configurable and cost-effective notebook PC. Confidently deploy the HP ProBook 650 which combines support for advanced features that provide long-term stability with excellent security for today's business. Ideal for professionals in corporate settings or small to medium businesses, wanting an affordable combination of innovation, essential security and multimedia capabilities.
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 650 with AMD Radeon discrete graphics 2GB-GDDR5.
  • Customized protection
    HP BIOSphere boosts security and keeps mission-critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
  • Cut out the chatter
    Help suppress ambient noise including keyboard clicks with HP Noise Reduction Software.
  • Give your speakers a boost
    Help make good speakers sound great with the HP Clear Sound Amp.
  • Tested to go the distance
    Stand up to the workload with a ProBook that passed MIL-STD 810G testing.
  • Protect against minor spills
    Help protect your ProBook with a spill-resistant HP Premium Keyboard with backlit options available.
HP ProBook 650 G2 Notebook - 15.6" - Intel Core i3 - 6100U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 7 Pro 64-bit (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Intel Core i3 (6th Gen) - 6100U / 2.3 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 520
Input Device
Pointing stick
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell - up to 9.75 hours
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
37.8 cm x 25.7 cm x 2.74 cm
2.31 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence - English
Processor / Chipset
CPU
Intel Core i3 (6th Gen) 6100U / 2.3 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD-ROM
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Camera Features
720p HD movie recording, low light enhancement
Sound
Stereo speakers, two microphones
High Definition Audio, DTS SOUND+
Input
Keyboard, touchpad, pointing stick
Keyboard Backlight
Keyboard Layout
Volume control, spill-resistant, touchpad with gesture support
Communications
Wireless
Network Interface
Gigabit Ethernet
IEEE 802.11, IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell
48 Wh
Run Time
Up to 9.75 hours
AC Adapter
Output
45 Watt
Connections & Expansion
Slots
1 x SIM card (1 free)
Interfaces Details
USB-C , USB 3.0 , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA , Serial , USB 3.0 (charging)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
Drivers & Utilities, CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP Connection Manager, HP ePrint, HP Hotkey Support, CyberLink YouCam BE, CyberLink PowerDVD BD Edition, Foxit PhantomPDF Express, Intel Wireless Display, HP Client Security, HP Systems Software Manager (free download), HP Secure Erase, HP Security Manager, HP GPS and Location, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP CIK for Microsoft SCCM (free download), HP 3D DriveGuard, HP Noise Reduction Software
Case Material
Polycarbonate ABS
Dockable
Security
HP 3D DriveGuard, HP DuraKeys, soft-touch surface, HP BIOS Protection, SecureBoot, HP Automatic Drive Lock, HP DriveLock, Hybrid Boot, Master Record Security, Measured Boot, Power On Authentication, Pre-Boot Security
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
Localization
2.31 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
