HP 640 G3 Intel Core i5 7200U 14" 4GB 500GB Windows 10 Pro
Quicklinx: CN36WS00 Mfr#: Z2W37ET#ABU
  • Core i5
  • IEEE 802.11n
Get the most from your investment with configurations that support today's technology and legacy devices. The HP ProBook 640 is equipped with the newest security and productivity features and is compatible with your existing IT investments.
Blend new features with proven technology
Simplify deployment of new PCs with the HP ProBook 640 that easily integrates into your current IT structure. Optional optical drives and legacy ports like a standard VGA port and RJ-45 connection help reduce the costs of upgrading your PCs.
Mobilize your workforce
Give your deskbound workforce the benefits of mobility without sacrificing performance or breaking the budget with 7th Gen Intel® Core™ i3/i5/i7 processors, expansive DDR4 memory, and peripherals like the HP UltraSlim dock.
HP exclusive security and manageability
Help prevent data breaches and downtime with HP BIOSphere Gen3 and self-encrypting. Simplify management with HP configuration across the globe, available in more than 180 countries where HP conducts business
  • Let nothing stand in your way
    Be productive in any situation. Experience the new features of Windows 10 Pro on the powerful, touch optional HP ProBook 640.
  • Powerful processing and drive options
    Powerful 7th Gen Intel Core i3/i5/i7 processors and configurable options let you deploy the right configuration based on user's needs.
  • Charge faster and go longer
    Replace batteries less often and quickly recharge your HP ProBook 640 with an HP fast charging battery. You'll get up to 90% battery life in just 90 minutes of charging.
  • Cut out the chatter
    Help suppress ambient noise including keyboard clicks with HP Noise Cancellation software.
  • Give your speakers a boost
    HP Audio Boost balances loudness and clarity, and enhances bass for improved speech quality.
  • Work without interruption
    Keep productivity high and downtime low with the fully integrated and automated features of the HP BIOSphere Gen3 firmware ecosystem. Your PCs have extra protection thanks to automatic updates and security checks.
HP ProBook 640 G3 Notebook - 14" - Intel Core i5 - 7200U - 4 GB RAM - 500 GB HDD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
4 GB DDR4 (1 x 4 GB)
Storage
500 GB HDD / 7200 rpm
Optical Drive
DVD-Writer
Display
14" WLED 1366 x 768 / HD
Graphics
Intel HD Graphics 620
Keyboard
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet
3-cell
Dockable
Security
Trusted Platform Module (TPM 1.2) Security Chip, fingerprint reader, smart card reader
34 cm x 23.7 cm x 2.7 cm
1.95 kg
Environmental Standards
- ENERGY STAR Qualified EPEAT Climate+
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i5 (7th Gen) 7200U / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
4 GB (1 x 4 GB)
Max RAM Supported
16 GB
DDR4 SDRAM
Speed
2133 MHz / PC4-17000
Rated Speed
2133 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
500 GB HDD SATA 6Gb/s / 7200 rpm
Optical Drive
DVD-Writer - tray
Display
14"
LCD Backlight Technology
WLED backlight
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Colour Gamut
45%
HD standard-viewing angle (SVA) eDP anti-glare
Audio & Video
Graphics Processor
Camera
Yes - 720p
Sound
Stereo speakers, two microphones
Input
Keyboard, touchpad
Keyboard Layout
Volume control, spill-resistant
Communications
Wireless
Bluetooth Class
Class 2
Wireless Controller
Intel Dual Band Wireless-AC 7265 - PCI Express Mini Card (M.2)
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
IEEE 802.3ab, IEEE 802.1x, IEEE 802.11i, Wi-Fi CERTIFIED
3-cell Lithium Ion
48 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
Interfaces Details
USB-C , USB 3.0 , USB 3.0 (charging) , LAN , Dock , Headphone/microphone combo jack , DisplayPort , VGA
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Software
Software Included
CyberLink Power2Go, Skype, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, HP Hotkey Support, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, CyberLink Power Media Player, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP 3D DriveGuard, HP Mobile Connect Pro, HP Image Assistant, HP JumpStart, HP Workwise, HP Noise Cancellation, HP LAN-WLAN Protection, HP MAC Address Manager, HP MIK for Microsoft SCCM (free download), HP Client Security Suite Gen3
Dockable
Security
DriveLock, HP 3D DriveGuard, Automatic DriveLock, Master Record Security, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
RoHS, WEEE, Common Criteria EAL4+
Localization
1.95 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Climate+
ENERGY STAR Certified
