The new modern design of the HP ProBook 630 brings style to the enterprise and delivers the performance, durability, security, and manageability required for a range of users and budgets.
Windows 10 Pro
Work anywhere without compromising on performance or security with Windows 10 Pro. FREE upgrade to Windows 11 when available. -
High performance, high portability
Help speed up demanding business applications with a quad-core 11th Gen Intel Core processor, with breakthrough Intel Iris Xe graphics. -
Fast and efficient wireless LAN
The portability of your PC and the reliability of a fast connection determines where you can work. Get a fast and reliable connection in dense wireless environments with gigabit-speed Wi-Fi 6. -
Preserve your privacy
Never wonder if someone is watching you with the added peace-of-mind that comes from the integrated HP Privacy Camera, with a physical shutter to protect from malicious surveillance. -
Automatic recovery from firmware attacks
Firmware attacks can completely devastate your PC. Stay protected with HP's self-healing BIOS - HP Sure Start Gen6 automatically recovers the BIOS from malware, rootkits, or corruption. -
HP Sure Sense
Malware is evolving rapidly and traditional antivirus can't always recognize new attacks. Protect your PC against never-before-seen attacks with HP Sure Sense, which uses deep learning AI to provide exceptional protection against advanced malware.
- HP ProBook 630 G8 Notebook - 13.3" - Intel Core i5 1145G7 - vPro - 8 GB RAM - 256 GB SSD - UK
- Product Type
- Notebook
- Operating System
- Win 10 Pro 64-bit - English
- Platform Technology
- Intel vPro Platform
- Processor
- Intel Core i5 (11th Gen) 1145G7 (4.4 GHz) / 8 MB Cache
- Memory
- 8 GB DDR4 (1 x 8 GB)
- Storage
- 256 GB SSD - NVMe, HP Value
- Display
- 13.3" WLED 1920 x 1080 / Full HD @ 60 Hz
- Graphics
- Intel Iris Xe Graphics
- Input Device
- ClickPad
- Keyboard
- UK
- Integrated Webcam
- Networking
- 802.11a/b/g/n/ac/ax, Bluetooth 5.1
- Battery
- 3-cell - up to 12.75 hours
- Security
- Firmware Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
- Pike silver aluminium
- 30.69 cm x 20.84 cm x 1.59 cm
- 1.28 kg
- Localisation
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - parts and labour - 1 year
- Product Type
- Notebook
- Operating System
- Windows 10 Pro 64-bit Edition - English
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.4 GHz
- Number of Cores
- Quad-Core
- Cache
- 8 MB
- Intel Turbo Boost Technology 2.0
- RAM
- 8 GB (1 x 8 GB)
- Max RAM Supported
- 64 GB
- Technology
- DDR4 SDRAM - non-ECC
- Speed
- 3200 MHz
- Rated Speed
- 3200 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 2
- Empty Slots
- 1
Storage
- Main Storage
- 256 GB SSD M.2 2280 PCIe - NVM Express (NVMe), HP Value
Display
- 13.3"
- LCD Backlight Technology
- WLED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 60 Hz
- Widescreen
- Image Brightness
- 250 cd/m²
- Colour Gamut
- 45% NTSC
- Full HD ultra wide-viewing angle (UWVA) eDP anti-glare
- Keyboard Name
- HP Premium
Audio & Video
- Graphics Processor
- Camera
- Yes - HD
- Video Resolutions
- 720p
- Sound
- Stereo speakers, dual array microphone
Input
- Keyboard, ClickPad
- Keyboard Layout
- UK
- Spill-resistant, ClickPad with gesture support
Communications
- Wireless
- Bluetooth Class
- Class 2
- Wireless Controller
- Intel Wi-Fi 6 AX 201 - PCI Express Mini Card (M.2)
- Dual stream (2x2), MU-MIMO, CNVi
- IEEE 802.11d, IEEE 802.11i, IEEE 802.11h, IEEE 802.11e, IEEE 802.11k, IEEE 802.11r, IEEE 802.11v
- Technology
- 3-cell lithium polymer
- Capacity
- 45 Wh
- Run Time
- Up to 12.75 hours
AC Adapter
- Input
- AC 115/230 V (50/60 Hz)
- Output
- 45 Watt, 19.5 V
Connections & Expansion
- HDMI , Headphone/microphone combo jack , USB4 (supports Thunderbolt 4, DisplayPort Alt Mode) (Power Delivery) , USB 3.2 Gen 1 (charging) , USB 3.2 Gen 1
Software
- Software Included
- HP Support Assistant, HP Power Manager, HP Hotkey Support, HP Wireless Button Driver, HP BIOS Configuration Utility (free download), HP Drive Packs (free download), HP Client Catalogue (free download), HP Image Assistant, HP LAN-WLAN Protection, HP Notifications, HP System Software Manager (free download), HP Connection Optimizer, HP Manageability & Integration Kit Gen3 (free download), HP Privacy Settings, HP Client Management Script Library (free download), myHP, Touchpoint Customiser for Commercial, HSA Fusion for Commercial, HSA Telemetry for Commercial, HP Noise Cancellation Software, HP Smart Support (free download)
- Security
- Power-on password, USB port control, Setup Password, BIOS Absolute Persistence, Power On Authentication, Pre-Boot Security, HP Sure Click, HP BIOSphere Gen 5, HP Sure Sense, HP Secure Erase, HP Sure Start Gen 6, HP Sure Admin, HP Sure Run Gen 4, HP Client Security Manager Gen 7, HP Sure Recover Gen 4, NVMe Driverlock, BIOS update over Wi-Fi
- Theft/Intrusion Protection
- Security Slot Type
- Kensington nano security slot
- Included Accessories
- HP 45 Watt Smart nPFC AC Adapter
- CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, KC, CIT, ICCP, BNCI
- Localization
- 1.28 kg
Sustainability Information
- ENERGY STAR Certified
- 0 °C
- 35 °C
- 10 - 90% (non-condensing)
- Shock Tolerance (operating)
- 40 g @ 2 ms half-sine
- Shock Tolerance (non-operating)
- 200 g @ 2 ms half-sine
- Vibration Tolerance (operating)
- 0.75 g @ RMS (random)
- Vibration Tolerance (non-operating)
- 1.5 g @ RMS (random)
Essential Accessories (4)
Get more from your purchase from one of our essential accessories
HP 65W Smart AC Adapter | In Stock | £18.31 |
HP USB-C Dock G5 Docking Station USB-C GigE 100 Watt | In Stock | £147.06 |
HP USB-C/A Universal Dock G2 - Docking station - USB-C HDMI DP GigE 100 Watt | In Stock | £206.71 |
HP Travel Hub G2 Port replicator USB-C VGA, HDMI for Chromebook | In Stock | £41.06 |
Warranty Packs (1)
Protect your investment by taking out one of our great value warranty packs
HP Care Pack Next Business Day Hardware Support - extended service agreement - 3 years - on-site | In Stock | £129.73 |
Other bundles (25)
HPE HDMI to DVI Adapter | In Stock | £9.89 |
HP USB-C To VGA Adapter | In Stock | £22.68 |
HP USB Travel Mouse | In Stock | £10.14 |
HP DreamColour 31.1" 4096x2160 10ms 2xHDMI 2xDisplayPort USB-C LED Monitor | In Stock | £2,821.06 |
HP Premium Wireless Mouse | In Stock | £38.00 |
HP USB-C to DisplayPort Adapter | In Stock | £23.53 |
HP USB-C to HDMI 2.0 Adapter | In Stock | £47.06 |
HP E 24" G4 WUXGA 1920 x 1200 LED Backlit Monitor | In Stock | £144.44 |
HP Z24f G3 24"1920x1080 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £210.83 |
HP P34hc G4 34" 3440x1440 5ms HDMI DisplayPort USB-C LED Curved Monitor | In Stock | £373.33 |
HP Z24n G3 24" 1920x1200 5ms HDMI DisplayPort IPS LED Monitor | In Stock | £223.10 |
HP P24v G4 23.8" 1920x1080 5ms VGA HDMI LED Monitor | In Stock | £82.34 |
Poly Blackwire 3320 USB-A ON-Ear Wired Headset | In Stock | £29.23 |
Poly P5 1080P HD Webcam | In Stock | £42.43 |
Poly Blackwire 3320 Microsoft Teams Certified USB-A Headset | In Stock | £30.17 |
Poly Voyager Focus 2 UC-M USB-A with Stand | In Stock | £146.75 |
Poly Blackwire 8225 USB-A Headset | In Stock | £112.09 |
Poly Voyager 4320 UC V4320-M C USB-A CS WW | In Stock | £115.37 |
Poly Voyager 4320 UC V4320 C USB-A CS WW | In Stock | £115.37 |
Poly Sync 20 SY20-M USB-A WW | In Stock | £66.31 |
Poly Voyager 4310 UC V4310-M C USB-A CS WW | In Stock | £106.40 |
Poly Voyager 4310 UC V4310 C USB-A CS WW | In Stock | £106.40 |
Poly Sync 10 SY10-M USB-A/C WW | In Stock | £52.73 |
Poly Sync 40 SY40-M WW | In Stock | £125.25 |
Poly Voyager Focus 2 UC USB-A Headset with Stand | In Stock | £142.42 |
