HP 4GB DDR4-2666 DIMM Memory
Quicklinx: F6X1WS00 Mfr#: 3TK85AT
Type: DDR4 SDRAM
Capacity: 4GB
Connection: DIMM 288-pin
Speed: 2666MHz
Registered/Buffered: Unbuffered
Hurry, only 1 left in stock!
£48.59 ex VAT
£58.30 inc VAT
Boost the capabilities of your HP Business Desktop PC and improve system performance and application responsiveness with low-power, high-speed DDR4 memory from HP.
  • Flexible, fast scalability
    Improve start-up times with fewer delays during routine operations, run more programs simultaneously, and easily toggle between them with super-fast, power-efficient memory that you can scale to meet your exact requirements.
  • HP-tested
    Ensure that all of your memory characteristics match by upgrading with HP-branded memory that's been tested for seamless system-level integration with HP PCs.
  • Supported by HP
    Protect your investment with the same world-class HP limited warranty you get for your PC.
HP - DDR4 - 4 GB - DIMM 288-pin - unbuffered
RAM memory
4 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2666 MHz (PC4-21300)
Unbuffered
Voltage
1.2 V
HP L26005-001, HP 3TK85AT
Pricing Type
Promo
HP 280 G3, 285 G3, 290 G2; Desktop Pro A G2; EliteDesk 705 G4, 800 G4, 800 G5; ProDesk 400 G5, 400 G6, 600 G3, 600 G4, 600 G5; Workstation Z1 G5 Entry
4 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
DIMM 288-pin
Speed
Non-ECC
Unbuffered
Voltage
1.2 V
Pricing Type
Promo
HP 280 G3, 285 G3, 290 G2 , HP Desktop Pro A G2 , HP EliteDesk 705 G4, 800 G4, 800 G5 , HP ProDesk 400 G5, 400 G6, 600 G3, 600 G4, 600 G5 , HP Workstation Z1 G5 Entry
Type: DDR4 SDRAM
Capacity: 4GB
Speed: 2666MHz
Brand: HP
Price Range Ex VAT: 0 - 50
