HP 4730s Intel® Core™ i5-2450M, 4GB, 640GB, 17.3", Windows 7 Professional 64-Bit
Quicklinx: 7XZKWS00 Mfr#: A6E51EA#ABU
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
Stylish performance. Watch, present, video conference , and multitask on this durable, stylish notebook. This versatile and secure HP ProBook boasts a 43,9 cm (17.3") diagonal HD monitor to make an impression in and out of the office.
  • Equipped to get the job done
    Gain strong processor capabilities, wireless functionality and a 43,9 cm (17.3") diagonal HD display.
  • Stylish design
    The metallic gray color complements the vertically brushed aluminum finish. Your PC's good looks stand up to the commute between home and work with added aluminum casing.
  • Security beyond passwords
    Secure access to your information, using HP Face Recognition or fingerprint-reading technology, and protect your notebook and the sensitive data it holds with HP ProtectTools (select models).
  • Easily stay productive
    Use HP QuickWeb to access the internet, email, contacts and calendar fast at the touch of a button without long boot-up times.
  • Crystal clear collaboration
    Reduce your communication costs and improve your productivity with HD webcam, for video conferencing, dual array microphones and SRS Premium Sound for better sound quality.
  • The best of both worlds
    With Switchable Graphics, you can get high performance from discrete graphics or the long battery life of integrated graphics in the same notebook.
HP ProBook 4730s - 17.3" - Intel Core i5 - 2450M - 4 GB RAM - 640 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit
Intel Core i5 (2nd Gen) - 2450M / 2.5 GHz, up to 3.1 GHz / 3 MB Cache
4 GB DDR3
Storage
640 GB HDD / 5400 rpm
Optical Drive
DVD SuperMulti
Display
17.3" LED backlight HD+ anti-glare 1600 x 900 / HD+
Graphics
AMD Radeon HD 6490M
Video Memory
GDDR5 SDRAM
Numeric Keypad
802.11b/g/n, Bluetooth 2.1, Bluetooth 3.0 HS, Gigabit Ethernet
Stereo speakers
Security
Fingerprint reader
41.4 cm x 27.9 cm x 2.9 cm
3.1 kg
Microsoft Office Preloaded
Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC.
Limited warranty - 1 year , Limited warranty - battery - 1 year
Notebook
Recommended Use
Small business, corporate business
Operating System
Processor / Chipset
CPU
Intel Core i5 (2nd Gen) 2450M / 2.5 GHz
Max Turbo Speed
3.1 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Chipset
Mobile Intel HM65 Express
RAM
4 GB
Max RAM Supported
8 GB
DDR3 SDRAM
Speed
1333 MHz / PC3-10600
Rated Speed
1333 MHz
SO-DIMM 204-pin
Storage
Main Storage
640 GB HDD SATA 3Gb/s / 5400 rpm
Optical Drive
DVD±RW (±R DL) / DVD-RAM fixed
Read Speed
24x (CD) / 8x (DVD)
Write Speed
24x (CD) / 8x (DVD±R) / 6x (DVD±R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM)
Display
17.3"
LCD Backlight Technology
LED backlight
Resolution
1600 x 900 (HD+)
Widescreen
Image Aspect Ratio
16:9
HD+ anti-glare
Audio & Video
Graphics Processor
AMD Radeon HD 6490M
Video Memory
GDDR5 SDRAM
Sound
Stereo speakers, microphone
Codec
IDT 92HD87
SRS Premium Sound, High Definition Audio
Input
Keyboard, touchpad
Numeric Keypad
Spill-resistant
Communications
Wireless
Network Interface
Gigabit Ethernet
Remote Management Protocol
SNMP
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.1x, Wi-Fi CERTIFIED, IEEE 802.3az
Lithium Ion
Installed Qty
1
AC Adapter
Input
Output
90 Watt, 19 V
Connections & Expansion
Slots
1 x ExpressCard/34 (1 free)
Interfaces Details
VGA , HDMI , Microphone input , Headphone output , 4 x USB 2.0 , LAN
Memory Card Reader
Yes (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, microSD)
Software
Software Included
HP ProtectTools Security Manager, Skype, HP Recovery Manager, HP Support Assistant, HP QuickWeb, HP Power Assistant, HP DayStarter, Microsoft Office 2010 Starter, HP SoftPaq Download Manager (free download), PDF Complete Special Edition (60 days trial), Norton Internet Security 2011 (60 days subscription), ArcSoft TotalMedia Suite, HP Connection Manager 4.0, HP Hotkey Support, HP ProtectTools for Central Management
Integrated Options
Stereo speakers
Security
Fingerprint reader
Security lock slot (cable lock sold separately), HP 3D DriveGuard, HP DuraFinish, Enhanced Pre-Boot Security, HP SpareKey, One-Step Logon, HP File Sanitizer
Power adapter
ACPI, CSA, UL, VCCI, BSMI, CCC, FCC, RoHS, KCC, WEEE, A-Tick, ICES
Localization
3.1 kg
5 °C
35 °C
10 - 90% (non-condensing)
Shock Tolerance
125 g @ 2ms half-sine pulse (operating) / 200 g @ 2ms half-sine pulse (non-operating)
Vibration Tolerance
0.75 g @ RMS (random) (operating) / 1.5 g @ RMS (random) (non-operating)
