HP 45W USB-C G2 Power Adapter
Quicklinx: F6ZFWS00 Mfr#: 1HE07AA#ABU
More than 50 in stock
£31.06 ex VAT
£37.27 inc VAT
Power and charge your notebook or tablet from its USB-C port with the HP 45W USB-C G2 Power Adapter.
  • Simple to use
    Connect one end of the adapter to the USB-C port on your device, and plug the AC head into any available wall outlet.
  • Easy to carry and store
    Pack the compact adapter inside your device's carrying case for easy, convenient charging and power whenever you need it.
  • World-class support
    Rest easy with a one-year limited warranty.
HP USB-C G2 - power adapter - 45 Watt
Power adapter - external
English / United Kingdom
Input Voltage
AC
Power Capacity
45 Watt
Input Connectors
24 pin USB-C
6.2 cm x 6.2 cm x 2.85 cm
1-year warranty
Chromebook 11 G9, 11MK G9, 14 G7; Chromebook x360; Elite x2; EliteBook 83X G7, 83X G8, 840, 845 G7, 84X G8, 855 G8, 85X G7; EliteBook x360; Mobile Thin Client mt22, mt45, mt46; Pro c640 G2, c645; ProBook 430 G7, 430 G8, 440 G7, 440 G8, 450 G7, 450 G8; ProBook x360; ZBook Firefly 14 G7, 15 G7
Input Voltage
AC
Input Connectors
24 pin USB-C
Power Capacity
45 Watt
Limited warranty - 1 year
6.2 cm
6.2 cm
2.85 cm
HP Chromebook 11 G6 (Education Edition), 11 G9, 11A G6, 11MK G9, 14 G5, 14 G7, 14A G5 , HP Chromebook x360 11 G1 (Education Edition), 11 G4, 11MK G3 , HP Elite x2 1012 G1, 1012 G2, G4, G8 , HP EliteBook 735 G5, 735 G6, 745 G5, 745 G6, 755 G5, 830 G5, 830 G6, 830 G7, 830 G8, 835 G7, 835 G8, 840 Aero G8, 840 G5, 840 G8, 840r G4, 845 G7, 845 G8, 850 G5, 850 G6, 850 G7, 855 G7, 855 G8 , HP EliteBook x360 1040 G6, 1040 G7, 1040 G8, 830 G5, 830 G6 , HP Mobile Thin Client mt22, mt45, mt46 , HP MX12 Retail Solution , HP Pro c640 G2 Chromebook, c640 G2 Chromebook Enterprise, c645 Chromebook, c645 Chromebook Enterprise , HP Pro x2 612 G2 , HP ProBook 430 G5, 430 G6, 430 G7, 430 G8, 440 G5, 440 G6, 440 G7, 440 G8, 445 G6, 445r G6, 450 G5, 450 G6, 450 G7, 450 G8, 455 G5, 455 G6, 455r G6, 470 G5, 640 G4, 640 G5, 645 G4, 650 G4, 650 G5 , HP ProBook x360 11 G5, 11 G6, 11 G7 , HP Spectre x360 15-ch006tx , HP ZBook 14u G6 Mobile Workstation, 15u G6 Mobile Workstation , HP ZBook Firefly 14 G7 Mobile Workstation, 15 G7 Mobile Workstation
Brand: HP
Stock Status: In stock
