HP 430 G6 I5 8265U 8GB 256 W10P
Quicklinx: F1Y3WS00 Mfr#: 5TJ81ET#ABU
Display Size: 13.3in
Processor Model: I5-8265U
Operating System: Windows 10 Pro 64-bit Edition
Installed Memory: 8GB
Hard Drive Capacity: 256GB
  • Core i5
  • IEEE 802.11n
More than 50 in stock
£721.90 ex VAT
£866.28 inc VAT
Standard delivery Delivered within 3-5 working days
Full-featured, thin, and light, the HP ProBook 430 lets professionals stay productive in the office and on the go. Stylish design plus optional quad-core performance and long battery life make this HP ProBook essential for today's workforce.
  • Affordable and stylish ultraslim design
    The HP ProBook 430 delivers stylish design to every business. An ultraslim chassis with crisp lines, clean edges, and a refined natural silver finish holds the near borderless display that opens 180°, making it easy to share content.
  • Security, durability, connectivity
    Your growing business requires a PC with business-class features. The secure HP ProBook 430 is enhanced with a range of security features and built with a durable chassis and connectivity options that can be specifically tailored to your needs.
  • Powerful processing
    Get through your deadline-driven, multi-tasking day using the HP ProBook 430, available with the latest optional 8th Gen quad-core Intel Core processor and a long battery life.
HP ProBook 430 G6 - 13.3" - Core i5 8265U - 8 GB RAM - 256 GB SSD - QWERTY UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i5 (8th Gen) 8265U / 1.6 GHz (3.9 GHz) / 6 MB Cache
8 GB DDR4 (1 x 8 GB)
Storage
256 GB - M.2 2280 SSD NVMe
Optical Drive
No optical drive
Display
13.3" WLED 1920 x 1080 / Full HD
Graphics
Intel UHD Graphics 620
Input Device
ClickPad
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet
3-cell
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader
30.85 cm x 23.1 cm x 1.8 cm
1.49 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.9 GHz
Number of Cores
Quad-Core
Cache
L3 - 6 MB
64-bit Computing
Intel Turbo Boost Technology 2.0, Intel Smart Cache
RAM
8 GB (1 x 8 GB)
Max RAM Supported
32 GB
DDR4 SDRAM
Speed
2400 MHz / PC4-19200 - 2400 MHz
Rated Speed
2400 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
1
Storage
Main Storage
256 GB SSD - (M.2 2280) PCIe - NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
WLED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Brightness
220 cd/m²
Full HD ultra wide-viewing angle (UWVA) eDP anti-glare, 67% sRGB colour gamut
Audio & Video
Graphics Processor
Camera
Yes - HD
Video Resolutions
720p
Sound
Stereo speakers, array microphone
Input
Keyboard, ClickPad
Keyboard Layout
QWERTY UK
Spill-resistant, multi-touch clickpad, ClickPad with gesture support
Communications
Wireless
Wireless Controller
Intel Wireless-AC 9560
Network Interface
Gigabit Ethernet
Ethernet Controller
Realtek RTL8111HSH-CG
Dual stream (2x2)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
3-cell Lithium Ion
45 Wh
AC Adapter
Input
Output
45 Watt, 19.5 V
Connections & Expansion
USB-C 3.1 Gen 1/DisplayPort (Power Delivery) , USB 3.1 Gen 1 , USB 3.1 (powered) , LAN , HDMI , Headphone/microphone combo jack
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card)
Security
BIOS Absolute Persistence, HP Automatic Drive Lock, HP DriveLock, Power On Authentication, Pre-boot Authentication
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
CSA, UL, VCCI, BSMI, GOST, SABS, CCC, FCC, A-Tick, ICES, KC, CIT
Localization
1.49 kg
ENERGY STAR Certified
35 °C
10 - 90% (non-condensing)
Shock Tolerance (operating)
40 g @ 2 ms half-sine pulse
Shock Tolerance (non-operating)
200 g @ 2 ms half-sine pulse
Vibration Tolerance (operating)
0.75 g @ RMS (random)
Vibration Tolerance (non-operating)
1.5 g @ RMS (random)
Software applications
HP 430 G6 I5 8265U 8GB 256 W10P Bundle deal on HP 430 G6 I5 8265U 8GB 256 W10P
£909.54
saving £8.33
£821.66
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F1Y3 040602
Condition: Customer return - item has been used and shows signs of use. PLEASE NOTE Some cosmetic damage. Scratch on the lid. Does not effect the working order of the laptop
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  £671.80
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Optical Storage: None
Graphics: Intel UHD Graphics 620
Hard Drive Type: SSD
Brand: HP
Stock Status: Used Stock
Price Range Ex VAT: 500 - 750
