The HP 4120 IP Phone Series is optimized for use with Microsoft Lync Unified Communications, and can support Office 365, Microsoft's familiar Office desktop suite combined with the latest, cloud-based versions of Microsoft's next-generation communications and collaboration services. All Lync-optimized IP phone features are supported by the HP 4120 IP Phone Series, including Microsoft's "Better Together" mode, which leverages Lync's powerful collaboration capabilities.
HP AllianceOne Integration
The HP 4120 IP Phone Series provides a rich set of unified communications features.Supports Microsoft "Better Together" mode.Office 365 integration is supported.The HP 4120 IP Phone Series is designed for standalone operation in a Lync environment.Delivers ease of configuration and installation. -
The HP 4120 IP Phone Series offers dual Gigabit Ethernet ports and connectivity as well as pass-through capability.IEEE 802.3af Power-over-Ethernet (PoE) Class 2 support simplifies deployment and dramatically reduces installation costs by helping to eliminate the time and cost involved in supplying local power.USB connectivity for 'Better Together' connectivity.Headset port provides wideband frequency response for use with optional external headset.Supports an optional external power supply unit adapter where PoE not available. -
Convergence
The series supports LLDP-MED (Media Endpoint Discovery) which defines a standard extension of LLDP which stores values for parameters such as QoS and VLAN to automatically configure network devices like IP phones. -
Phone Characteristics
The series offers Microsoft Real Time Audio (RTA) technology designed for both high-quality wideband and narrowband Voice over IP (VoIP) applications.G. 722 wideband audio codec support delivers voice calls with high-definition audio quality.G. 711 pulse-code modulation support provides for legacy voice encoding (A-law, µ-law).Support for a wide variety of audio codec and acoustic performance requirements provides quality voice communications, improving collaboration, boosting productivity, and reducing operating costs.Handset and speakerphone audio outputs supports wideband and Hearing Aid Compatibility (HAC) outputs.
- HPE 4120 IP Phone - VoIP phone
- Product Type
- VoIP phone
- Main Features
- Integrated Ethernet switch
- Voice Codecs
- G.722, G.711u, G.711a, RT Audio
- Speakerphone
- Call Services
- Voice Mail, Call Hold
- Display
- LED display - colour
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX/1000Base-T
- Compatible Software
- Microsoft Lync
- 1-year warranty
- Product Type
- VoIP phone
- Shipping Weight
- 1.5 kg
Phone Features
- Call Services
- Dialer Location
- Base
- Conference Call Capability
- Speakerphone
- Indicators
- Visual ringer light, speakerphone indicator, hold indicator, mute indicator
IP Telephony
- Main Features
- VoIP
- Voice Codecs
- Power Over Ethernet (PoE) Support
- Network Protocols
- Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED)
- Network Ports Qty
- Microsoft Lync
- Voice Features
- Comfort noise generation (CNG), voice activity detection (VAD), acoustic echo cancellation (AEC), automatic gain control (AGC)
- Network Features
- Class 2 PoE
Display
- Display Location
- Base
- Diagonal Size
- 3.5"
- Display Resolution
- 320 x 240 pixels
- Connections
- Headset jack , USB
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
- Cables Included
- Network cable - 1.8 m
- Included Accessories
- Stand
Dimensions & Weight (Base)
- 22.5 cm
- 4.19 cm
- 23.8 cm
- 1.5 kg
- Shipping Weight
- 1.5 kg
- Limited warranty - 1 year
