HP 400 G3 SFF Intel Core i5-6500 4 GB 128 GB
Quicklinx: CP92WS00 Mfr#: Z6R99EA#ABU
Processor Type: Core i5
Operating System: Windows 10 Home 64-bit Edition
Installed Memory: 4GB
Hard Drive Capacity: 128GB
Storage Type: SSD
  • Core i5
£490.61 ex VAT
£588.73 inc VAT
Give your business the strong foundation it needs for growth with the affordable and reliable HP ProDesk 400 SFF. Designed with essential security and manageability features, the HP ProDesk 400 helps keep your business growing.
Let nothing stand in your way
Help protect from today’s security threats and maximize management and productivity features for business with Windows 10 Pro.
Simplify device management
Reduce the complexity of administration. HP Touchpoint Manager, Windows 10 Pro manageability features, and HP Common Core BIOS help you easily manage assets.
Communication made easy
Make conferencing from your PC as simple as the touch of a button with the optional HP Conferencing keyboard.
Connect to more capabilities
Multiple displays have shown to help increase productivity by 35% and the HP ProDesk 400 SFF allows you to connect two optional HP Pro Displays right out-of-the-box.
Green with envy
Reduce energy consumption and costs with ENERGY STAR® and EPEAT® Gold certified configurations.
Cloud-based IT management made simple
Manage data, security, and devices from a single cloud-based solution with HP Touchpoint Manager.
Valuable support at your service
Simplify technical support with Helpdesk by HP Care. Rely on cost-effective expertise that’s available 24x7, covering multiple brands, devices and operating systems.
  • New powerful processors
    New 6th Gen Intel Core processors bring powerful processing with Intel HD 530 Graphics. Available DDR4 memory helps meet the demands of today's businesses.
  • Security from the start
    HP BIOSphere and HP Client Security boost security and keep critical data and systems under lock and key with customizable authentication and BIOS-level passwords.
  • Tested to go the distance
    HP ProDesks are rigorously tested to help ensure reliability. During the HP Total Test Process, PCs experience 120,000 hours of performance trials to help get you through your business day.
  • Make the smart investment
    The HP ProDesk 400 SFF helps affordably build a solid IT infrastructure for your growing business and fits in smaller workspaces for easy deployment.
HP ProDesk 400 G3 - SFF - Core i5 6500 3.2 GHz - 4 GB - 128 GB - UK
Personal computer - small form factor
1 x Intel Core i5 (6th Gen) 6500 / 3.2 GHz (3.6 GHz) (Quad-Core)
Processor Main Features
Intel Turbo Boost Technology 2
Cache Memory
6 MB
Cache Per Processor
6 MB
RAM
4 GB (installed) / 32 GB (max) DDR4 SDRAM - non-ECC - PC4-17000
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 128 GB - SATA 6Gb/s - 2.5" - HP Value
Optical Storage
DVD-Writer
Graphics Controller
Intel HD Graphics 530 Dynamic Video Memory Technology
Audio Output
Stereo
GigE
Keyboard
OS Provided
27 cm x 29.95 cm x 9.5 cm
4.43 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - parts and labour - 1 year - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Processor / Chipset
CPU
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Upgradable
Chipset Type
Intel H110 Express
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 32 GB (max)
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
2 (Total) / 1 (empty)
Unbuffered, dual channel memory architecture
Configuration Features
1 x 4 GB
Hard Drive
SSD - 2.5"
1 x 128 GB
Interface Type
SATA 6Gb/s
HP Value
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Video Interfaces
VGA, DisplayPort
HDCP Compatible
Max Monitors Supported
3
Audio Output
Sound Output Mode
Stereo
Max Sampling Rate
192 kHz
High Definition Audio, DTS SOUND+
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
HP Business Slim Keyboard
USB
Localization & Layout
Mouse
USB
Interface (Bus) Type
PCI Express 1.1 x1
Ethernet Controller
Realtek RTL8111HSH-CG
Remote Management Protocol
SNMP 2
Wake on LAN (WoL), ACPI support, PXE support, auto-uplink (auto MDI/MDI-X)
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 1 (free) x external , 1 (total) / 0 (free) x internal 2.5" / 3.5" shared
Slots
1 (total) / 1 (free) x PCIe 2.0 x1 - low-profile , 1 (total) / 1 (free) x PCIe 3.0 x16 - low-profile , 1 (total) / 0 (free) x CPU , 2 (total) / 1 (free) x DIMM 288-pin
4 x USB 3.0 (2 front, 2 rear) , 4 x USB 2.0 (two of them with wake functionality) , 1 x serial , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x DisplayPort , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 1 x audio line-in , 1 x audio line-out , 1 x LAN (Gigabit Ethernet) - RJ-45
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
ACPI, RoHS, WEEE, Common Criteria EAL4+
Power supply
Nominal Voltage
Power Provided
180 Watt
80 PLUS Certification
80 PLUS Bronze
Efficiency
85%
Power Factor Correction
Yes (active)
Operating System / Software
OS Provided
Windows 10 Home 64-bit Edition English
Software
CyberLink Power2Go, HP Recovery Disc Creator, Skype, Microsoft Security Essentials, HP SoftPaq Download Manager, HP Recovery Manager, HP Support Assistant, Bing Toolbar, HP ePrint, CyberLink PowerDVD BD Edition, Windows Defender, HP Systems Software Manager (free download), HP Secure Erase, HP BIOSphere, HP BIOS Configuration Utility (free download), HP Client Catalogue (free download), HP Client Security Manager, HP CIK for Microsoft SCCM (free download)
ENERGY STAR Certified
27 cm
29.95 cm
9.5 cm
4.43 kg
10 °C
35 °C
10 - 90% (non-condensing)
HP 400 G3 SFF Intel Core i5-6500 4 GB 128 GB Bundle deal on HP 400 G3 SFF Intel Core i5-6500 4 GB 128 GB
£589.78
Storage Type: SSD
Processor Model: I5-6500
Type: Personal computer
Case Style: Small form factor
Optical Storage: DVD-Writer
Brand: HP
Price Range Ex VAT: 300 - 500
