Expand your view in comfort with a spacious, thoughtfully designed 23.8 inches of workspace. Boasting a crisp, smooth screen and a simple yet functional design, this HP Series 3 Pro 23.8" FHD monitor lets you work better all day.
IPS Technology
No matter where you stand, IPS technology ensures image accuracy and consistency across wide 178-degrees horizontal and vertical viewing angles. -
HP Eye Ease
HP Eye Ease, an always-on, hardware low-blue light filter, helps keep your eyes comfortable throughout the day by reducing blue light without the yellow color shift. -
100 Hz Refresh Rate
Experience smooth scrolling, life-like video and clear detail with a 100 Hz refresh rate that provides fluid movement from frame to frame. -
Height and Tilt Adjust
The 100 mm height- and tilt-adjustable slim stand helps you find the right angle so you can maximize productivity and work comfortably. -
Plenty of Ports
This monitor is ready to connect for sharp FHD visuals with multiple ports including 1 x VGA, 1 x HDMI 1.4, and 1 x DisplayPort 1.2. -
3-Sided Micro-Edge Bezel
See and do more on your screen with a 3-sided micro-edge bezel that maximizes your viewing area for a sleek design and virtually seamless dual-monitor setups.
 - HP 324ph - Series 3 Pro - LED monitor - Full HD (1080p) - 24" - Smart Buy
 - LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/2239418
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 14 W
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 8000000:1 (dynamic)
- Response Time
 - 5 ms (grey-to-grey with overdrive)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 72% NTSC
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, tilt
- Screen Coating
 - Anti-glare, 3H Hard Coating, Haze 25%
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Black
 - 53.89 cm x 19.63 cm x 46.92 cm
 - 4.71 kg
- Localisation
 - English / United Kingdom
- Manufacturer Selling Program
 - HP Smart Buy
- Environmental Standards
 - ENERGY STAR Qualified EPEAT Gold
 - VCCI, C-Tick, BSMI, NOM, CCC, IC, PSB, FCC, ISO 9241-307, KCC, Energy-using Products (EuP) Lot 6, PSE Mark, cTUVus, TUV Bauart, E-Standby, CEC, KC, CEL, EAC, ISC, RCM, CEL Grade 2, SEPA, BIS, low halogen, Energy-using Products (EuP) Lot 5, NRCS, Mexico Energy label, Energy-using Products (EuP) Lot 26, CB 60950, UAE, CB 62368-1, Vietnam MEPS, South Africa Energy Label, Ukraine Energy Label, TGM, Australia MEPS, Works With Chromebook (WWCB) certified, Argentina S-Mark, Ukraine CoC, Ukraine DOC
 - 3-year warranty
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 24"
- Viewable Size
 - 23.8"
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Pixel Per Inch
 - 93
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
 - 72% NTSC
- Response Time
- Vertical Refresh Rate
 - 48 - 100 Hz
- Horizontal Refresh Rate
 - 30 - 115 kHz
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
- Backlight Technology
 - Edge-lit LED
 - Flicker Free technology, Low Blue Light technology, 8-bit(6-bit + FRC) Colour Depth, HP Eye Ease, 3-sided borderless
 - Black
 - 53.89 cm x 19.63 cm x 46.92 cm - with stand
 - 4.71 kg
Audio
 - Speakers
- Output Power / Channel
 - 2 Watt
 - HDMI (HDCP) , VGA , DisplayPort 1.2 (HDCP)
Mechanical
 - Height, tilt
- Tilt Angle
 - -5/+23
- Height Adjustment
 - 100 mm
- VESA Mounting Interface
 - 100 x 100 mm
 - Security lock slot (cable lock sold separately), detachable stand, VESA interface support
- Cables Included
 - 1 x HDMI cable
- Backlight Life
 - 30,000 hours
- Localisation
 - HP Smart Buy
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 14 W
- Power Consumption SDR (On mode)
 - 14 kWh/1000h
- Power Consumption (Typical)
 - 23 Watt
- Power Consumption (Max)
 - 35 Watt
- Power Consumption Stand by
 - 0.5 Watt
- Included Software
 - HP Client Management Script Library, HP Display Center
- Dimensions & Weight Details
 - With stand - width: 53.89 cm - depth: 19.63 cm - height: 46.92 cm - weight: 4.71 kg , Without stand - width: 53.89 cm - depth: 4.94 cm - height: 32.42 cm - weight: 3.4 kg
- Shipping Width
 - 59.5 cm
- Shipping Depth
 - 12.4 cm
- Shipping Height
 - 39.1 cm
- Shipping Weight
 - 6.74 kg
Sustainability Information
- EPEAT Compliant
 - EPEAT Gold
- ENERGY STAR Certified
 - Limited warranty - 3 years
 - 5 °C
 - 35 °C
 - 20 - 80% RH (non-condensing)
