HP 310 23.6" AIO Zero Client Teradici 2321 512MB
Quicklinx: BCZ6WS00 Mfr#: J2N80AA#ABU
Operating System: [N/A]
Processor Type: Tera2321
Processor Model: Teradici 2321
Installed Memory: 512MB
Hard Drive Capacity: 0GB
£594.09 ex VAT
£712.90 inc VAT
Maximize available workspace while saving time and money with the PCoIP-optimized HP t310 AiO Thin Client that connects users to your VMware networks in no time.
  • Small size, big performance
    Enjoy a seamless, high-performance VMware desktop driven by Tera 2 PCoIP that delivers low display latency and fast response time, even for your most demanding applications.
  • Keep it simple
    Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients.
  • Be secure
    Keep all data in the data center with a thin client that transfers screens to the local user for an ultra-high level of security and easy client management. Reduce IT costs and simplify deployment with centralized support and management.
  • Rest easy with a smart investment
    Be future-ready with a 36-month long lifecycle that supports extended deployments, get global support from a standard three-year limited warranty, and help save money with an energy-efficient design that carries globally recognized eco-certifications.
HP t310 - all-in-one - Tera2321 - 512 MB - LED 23.6"
Zero client - all-in-one
1 x Teradici Tera2321
RAM
512 MB DDR3 SDRAM
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
23.6" - LED - 1920 x 1080 (Full HD)
Audio Output
Stereo - integrated
GigE
55.68 cm x 16.38 cm x 39.95 cm
3.99 kg
Limited warranty - parts and labour - 3 years
Zero client
Recommended Use
Small business, corporate business
Product Form Factor
All-in-one
Processor / Chipset
CPU
Teradici Tera2321
CPU Qty
1
Max CPU Qty
1
CPU Upgradability
Not upgradable
RAM
Installed Size
512 MB
DDR3 SDRAM
Effective Memory Speed
1333 MHz
Hard Drive
No HDD
Optical Storage
No optical drive
Monitor
Monitor Type
LED
Diagonal Size
23.6"
Native Resolution
Widescreen Display
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Pixel Pitch
0.2715 mm
Response Time
5 ms
Image Brightness
300 cd/m²
Graphics Controller
Integrated
Audio Output
Integrated
Sound Output Mode
Stereo
Max Sampling Rate
96 kHz
Input Device
Mouse, keyboard
Keyboard
USB
Mouse
USB
Integrated
Wake on LAN (WoL), DHCP support
6 x USB 2.0 , 1 x microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-I
PC over IP (PCoIP) technology
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
VCCI, EN 61000-3-2, ICES-003, ZH1 618, EN 61000-3-3, EN55024, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, AES-256
Power adapter
Nominal Voltage
Power Provided
65 Watt
55.68 cm
16.38 cm
39.95 cm
3.99 kg
10 °C
10 - 90% (non-condensing)
HP 310 23.6 Bundle deal on HP 310 23.6" AIO Zero Client Teradici 2321 512MB
£773.95
saving £3.64
£693.26
Storage Type: No HDD
Optical Storage: None
Display Size: 23.6"
Brand: HP
Price Range Ex VAT: 500 - 750
