Maximize available workspace while saving time and money with the PCoIP-optimized HP t310 AiO Thin Client that connects users to your VMware networks in no time.
Small size, big performance
Enjoy a seamless, high-performance VMware desktop driven by Tera 2 PCoIP that delivers low display latency and fast response time, even for your most demanding applications. -
Keep it simple
Make it easy to deploy, manage, and maintain your install base with HP Device Manager, a software tool available exclusively for HP Thin Clients. -
Be secure
Keep all data in the data center with a thin client that transfers screens to the local user for an ultra-high level of security and easy client management. Reduce IT costs and simplify deployment with centralized support and management. -
Rest easy with a smart investment
Be future-ready with a 36-month long lifecycle that supports extended deployments, get global support from a standard three-year limited warranty, and help save money with an energy-efficient design that carries globally recognized eco-certifications.
- HP t310 - all-in-one - Tera2321 Tera2321 - 512 MB - no HDD - LED 23.6"
- Zero client - all-in-one
- Localisation
- Processor
- 1 x Teradici Tera2321 Tera2321
- RAM
- 512 MB DDR3 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Monitor
- 23.6" - LED - 1920 x 1080 (Full HD)
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 55.68 cm x 16.38 cm x 39.95 cm
- 3.99 kg
- Limited warranty - parts and labour - 3 years
- Zero client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- Teradici Tera2321 Tera2321
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED
- Diagonal Size
- 23.6"
- Native Resolution
- Widescreen Display
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Pixel Pitch
- 0.2715 mm
- Response Time
- 5 ms
- Image Brightness
- 300 cd/m²
Graphics Controller
- Integrated
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 96 kHz
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support
- 6 x USB 2.0 , 1 x microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-I
- PC over IP (PCoIP) technology
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- VCCI, EN 61000-3-2, ICES-003, ZH1 618, EN 61000-3-3, EN55024, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, AES-256
- Power adapter
- Nominal Voltage
- Power Provided
- 65 Watt
- 55.68 cm
- 16.38 cm
- 39.95 cm
- 3.99 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
