Maximize available workspace while saving time and money with the PCoIP-optimized HP t310 AiO Thin Client that connects users to your VMware networks in no time.
The perfect fit
Get a fanless design and quiet thermals that support mass installments in small spaces plus a 23-inch diagonal screen that puts all your work front and center. -
The whole package
Be ready to go out of the box with an included keyboard and mouse. -
Make it yours
Customize your all-in-one with an array of inputs that support external peripherals, a second display, Ethernet, and audiovisual interactivity. -
Technology designed for VMware
Accelerate your hardware performance with Tera 2 PCoIP and the Teradici Tera 2321 processor. -
Virtually risk-free
Help protect your data and software by leaving it on the server, and your device with an optional HP Cable Lock. -
One world
Deploy the same configuration around the world with a Global Series SKU that ensures the same product everywhere you do business.
- HP t310 - all-in-one Tera2321 - 512 MB - no HDD - LED 23.6"
- Zero client - all-in-one - PC over IP (PCoIP) technology
- Localisation
- Processor
- 1 x Teradici Tera2321
- RAM
- 512 MB DDR3 SDRAM
- Hard Drive
- No HDD
- Optical Storage
- No optical drive
- Monitor
- 23.6" - LED - 1920 x 1080 (Full HD)
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- 55.68 cm x 16.38 cm x 39.95 cm
- 3.99 kg
- Limited warranty - parts and labour - 3 years
- Zero client
- Recommended Use
- Small business, corporate business
- Product Form Factor
- All-in-one
- Localisation
Processor / Chipset
- CPU
- Teradici Tera2321
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Upgradability
- Not upgradable
RAM
- Installed Size
- 512 MB
- Technology
- DDR3 SDRAM
- Effective Memory Speed
- 1333 MHz
Hard Drive
- No HDD
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED
- Diagonal Size
- 23.6"
- Native Resolution
- Widescreen Display
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Pixel Pitch
- 0.2715 mm
- Response Time
- 5 ms
- Image Brightness
- 300 cd/m²
Graphics Controller
- Integrated
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- Max Sampling Rate
- 96 kHz
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
Mouse
- Interface
- USB
- Integrated
- Data Link Protocol
- Wake on LAN (WoL), DHCP support
- 6 x USB 2.0 , 1 x microphone , 1 x headphones , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DVI-I
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- VESA Mounting Interface
- 100 x 100 mm
- VCCI, EN 61000-3-2, ICES-003, ZH1 618, EN 61000-3-3, EN55024, UL 60950-1, IEC 60950-1, EN 60950-1, AES-128, AES-256
- Power adapter
- Voltage Required
- Power Provided
- 65 Watt
- 55.68 cm
- 16.38 cm
- 39.95 cm
- 3.99 kg
- 10 °C
- 40 °C
- 10 - 90% (non-condensing)
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 3 Years Thin Client Only | In Stock | £24.71 |
HP Care Pack Next Day Exchange Hardware Support Extended Service Agreement 5 Years | In Stock | £48.26 |
HPE DisplayPort DVI-D Adapter | In Stock | £11.55 |
HPE DisplayPort to VGA Adapter | In Stock | £13.20 |
HP Keyed Cable Lock 10mm | In Stock | £26.40 |
